6° Rear Beams....Pics and info
Rubber Rhino Crew
Anyone got pics of a fully adjustable 6° rear cosworth beam? Just gauging whats adjustable and how it all goes together. Can someone explain where the 6° and 9° terms come from (I guess its the angle of the arm rotation).
Any pics appreciated.
Dan
Dan
Rubber Rhino Crew
Yeah I get you, but not looking to buy one just yet so a bit rude to ring up expecting a full explanation on how they are deigned and work... after all time is money to them as they're both businessmen.
So anyone got any info on this?
Rubber Rhino Crew
heard horror stories about zoo beams not being 6 degrees and not adjustable enough to sort out.
James90 Ahh so thats the reasoning behind the inner rose joints being vertical then.
I'm half thinking about making one myself out of a spare beam I have....hmmm
Dan
Dan
Rubber Rhino Crew
just viewed your beam James, must say it looks spot on! How much was it? where from?
You got me thinking now, I could make that & make it adjustable for camber too with a style of adjuster found on things like Adj TCAs and compression struts.
Hmmmm.....might give it a bash!
B1mbo
Dan
Dan
also to buy the rose joints will be an arm an a leg as ur only buyin 2 !
its probably easier and not much more expensive to buy one !
here is my attempt at explaining, basicly the angle refers to the angle i have tried to draw in my paint pic, the left side shows an 18 degree beam and the right side shows a modded 6 degree which has the inner wishbone pickup moved.
B1mbo
check half way down on this page mate its a pic of the rosejoint to adjust camber up/down and its slotted for toe forward and back ill get some good pics 2moz if u want ?
https://passionford.com/forum/showth...=242825&page=2
here is a decent pic, not as good as my drawing though
https://passionford.com/forum/showth...120362&page=25
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Tony W
09-09-2015 12:08 PM
