there a big difference between normal clutch and a alcon 6paddle
search ebay; i bought a virtualy brand new 6 paddle ap clutch set up for £120, with cover, flywheel and spade paddle plate (which needs new paddles)
make sure you get your flywheel skimmed when fitting a new clutch though
As above.
When I first went to an Alcon from a std clutch, with a new cable the new uprated clutch was actually a lot lighter pedal wise than the one that came out.
AP 6 paddle is considerably heavier compared to the Alcon kit, ime.
You can get worn clutches relined, but I'd be wary of the springs on the plate being fubar'd and could be wrong, but not sure these are replaced so you wouldn't then have the equivalent of a new plate.
Considering how long they last for an uprated part, I'd just change the whole shebang - plate, bearing, cable & cover.
JK12
33
26-04-2021 12:09 PM
