how can you tell if you have a clutch or gearbox prob
Old 09-06-2008, 07:29 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default how can you tell if you have a clutch or gearbox prob
i have crunching when i go from 2nd to 3rd and to 4th and down again and the biting point is right near top of pedal? any way of testing
Old 09-06-2008, 07:30 PM
Dicko&Vacant
Dicko&Vacant's Avatar
gear selector? My Golf Gti used to do that and when driving erratically i had managed to move gear selector slightly out of line
Sarah
Old 09-06-2008, 07:34 PM
Roosie
Roosie's Avatar
good point never thought of that
Old 09-06-2008, 07:38 PM
Dingy
Dingy's Avatar
been told my clutch is the problem with my box....
So i swapped the box and instantly fixed the problem LOL
Old 09-06-2008, 07:40 PM
Roosie
Roosie's Avatar
how much am i looking for a box change in labour?
Old 09-06-2008, 08:07 PM
foreigneRS
Testing the future
foreigneRS's Avatar
it's more than likely clutch if it's all of those gears both up and down
Old 09-06-2008, 09:03 PM
LHD220Turbo
LHD220Turbo's Avatar
what car is it on? if 2wd saff i change my clutch which i took the g/box out and it took just over an hour with 2 of us
Old 09-06-2008, 09:15 PM
Roosie
Roosie's Avatar
yes mate 2wd
Old 09-06-2008, 09:20 PM
LHD220Turbo
yes mate 2wd
piece of piss to do yourself mate
Old 09-06-2008, 09:22 PM
Roosie
Roosie's Avatar
my days of getting under a car is over lol what are we looking at realisticly from a garage
Old 09-06-2008, 09:27 PM
BigErn
BigErn's Avatar
Brandon as in Durham mate?
Old 09-06-2008, 09:30 PM
LHD220Turbo
depends on if you know someone or not, prices vary wildly, i got mine done for nothing but at most a garage should charge no more than 4 hours labour, on average Ł60 an hour
Old 09-06-2008, 09:31 PM
Roosie
Roosie's Avatar
brandon suffolkmate
Old 09-06-2008, 09:42 PM
BigErn
BigErn's Avatar
Shame, I was gonna offer to pop up and have a look for you. But you are a few too many miles from me at that Brandon
Old 10-06-2008, 03:16 AM
Roosie is TOO FAT to fit under the car, even on ramps!!
Old 10-06-2008, 04:09 AM
R5FORD
R5FORD's Avatar
sounds like clutch.. mine does the same and my clutch if fooked
waiting for my new engine and then il put a new clutch in aswel.
Old 10-06-2008, 08:25 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
If it only does it when changing gear fast and the clutch is engaging properly (as in not dragging when you select first with the clutch fully depressed), then it is the age old T5 problem of worn syncro rings. A clutch will not fix this.
Old 10-06-2008, 08:28 AM
Roosie
Roosie's Avatar
it does it when you change slowely and carefully as well as fast
Old 10-06-2008, 09:32 AM
Mike Rainbird
Caraholic
If the clutch is not dragging when you select first, then the syncros are REALLY fucked .
Old 10-06-2008, 09:41 AM
Roosie
Roosie's Avatar
first is fine so is 2nd
Old 10-06-2008, 09:59 AM
LHD220Turbo
i've replied to your wanted add re the T5; i have one in my shed
Old 10-06-2008, 10:10 AM
Mike Rainbird
Caraholic
Defo the syncros .
Old 10-06-2008, 08:10 PM
Red16
Red16's Avatar
what do you mean by draggin Mike? as in clutch biting slightly instead of being completely disengagaed?
Old 10-06-2008, 08:13 PM
Roosie
Roosie's Avatar
im going to have to get gearbox reconed and new clutch to make sure really.
Old 11-06-2008, 09:01 AM
Mike Rainbird
Caraholic
When the car is stationary and you try and select first gear, it won't go in easily, because the clutch is not disengaging properly and is still dragging on the flywheel.
arkeye
Ford Focus ST
20-02-2016 01:22 PM
mjonathan24
29-10-2015 10:39 PM
gcfcos
59
06-10-2015 05:04 PM
Iain Mac
30-09-2015 09:39 PM
Quick Reply: how can you tell if you have a clutch or gearbox prob
