stud and nut kit setings
DANISH cosworth abuser
If you use arp grease, then 40nm first time 80nm second time and 110nm third time then recheck if every nut have 110nm, then heat car up to normal driving temp, leave it for a day, then loosen nut half a turn, and tighten 110nm, but only one nut @ a time.
Have worked on thoose 5 engines i have made
ARP part number 251-4701 Ford Sierra/Escort Head stud Kit instructions state:
Use manufacturers torque sequence but do not use the engine manufacturers torque specs. Torque nuts to 80 ft lb for ARP MOLY ASSMBLY LUBRICANT (or ARP THREAD SEALER) or torque to 120 ft lb with 30wt Motor oil.
i posted up the intrustions word from word in the technical area ages ago lol
https://passionford.com/forum/technical-essay-archives/168323-arp-head-stud-and-nut-kit-fitting-instructions-here.html
I torque to 60lb ft, then 90lb ft, then 120lb ft, then leave a minimum of two hours, with group a and retorque to 120 again, LIGHTLY oil with engine oil.
chunk out of block wrecked crank, 1 snaped rod 3 bent 3 bent gudgeon pins when the rod exeted the block it also mashed the sump and it bent 2 valves
