Will 5x112 ET24 wheels fit a saph ?
Rally nut
I was wondering if 8x16" wheels with 5x112 and ET24 will fit a saph cosworth. I know I will have to use some sort of adaptators but would it be possible ?
saph stud pattern is 4x108,offset should be et35.you get get away with 35 and a spacer or it will hit the caliper.
you can put et25 escos rims on but there is a slim risk on lowered cars it will hit the arches.
as for adaptors,no-noe i know of at all does a converter for a 5 stud from a ford pattern
theres a focus in the picture section on here and hes got 5 stud wheels with a subaru stud pattern and he had is hubs welded and re drilled to correct size, seems a better way of doing it that hub adapters?
dojj,youve done what?fitted 5x112's or et24's?
theres no way a 5x112 will fit,unless theres a made up hub adaptor.which they do do for some german cars but not that ive ever come across for ford.
et24 is a possible fit as long as its 4x108.as long as you are aware it is very boarder line with the arches
just read the guys post and it was a different size but was 5 stud lol
heres the post i was on about tho.
https://passionford.com/forum/showth...ight=focus+bbs
steerfromdarear
28
29-01-2016 06:14 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
