Spark Pulg Guru's- Please help
I have a 4x4 saph on a j reg. It has a chip, bigger injectors, a 3bar map sensor. It holds around the 22psi mark under full throttle.
it was set up 3 days ago and it drives better than it ever has done scince owning it..
I had this annoying little problem where the car would slightly missfire under hard acc but only when you had been footing it quite a bit before hand. (only when the pulgs were really really hot)
The pulgs that were in the car were NGK BKR8EIX gapped to 1mm
I have just put a set of BCR8ES gapped to 1mm in, after being told they were really good and would suit fine. now the car missfires on boot all the time. anything over about 7 psi and the car badly missfires. i can only asume that the boost is blowing the spark out.
What i was wondering is if people on here have had this problem and wether these are the correct plugs or not?
or is the coil to weak.
just after some guildlines really.
thanks in advance
thanks in advance
re gapped them to 0.60mm seems alot better. still slightly misfires some of the time when giving it a hardcore thrashing.
next step will be a gp A coil me thinks
Thanks again for all the help
I remember when I got my cossie and gapped the plugs to 1.0mm, it would not even start and only fired once or twice when turning over, I foloowed the data on the intercooler panel!!
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
