idle speed control valve problems
Old May 18, 2008 | 06:21 PM
madcossy's Avatar
madcossy
Default idle speed control valve problems
can anyone help got 2wd cossy when i start my car in morning with iscv on it revs to 3000 revs bought new one and it still revs to 3000 any ideas
Old May 18, 2008 | 06:23 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
tps faulty or mis adjusted.
air leak? does it do it with the iscv unplugged?
Old May 18, 2008 | 06:29 PM
madcossy's Avatar
madcossy
no runs mint with it unplugged
Old May 18, 2008 | 06:32 PM
JTECH James
Passion for Fords!
tps is most likley then, if the ecu spots a open throttle it opens the iscv.
check wiring,and base setting
Old May 18, 2008 | 06:34 PM
BM08's Avatar
BM08
Had a escort gti, and we changed the iscv and it made no difference, the TPS did the trick and it never did it again in the 2 years i owned it
Old May 18, 2008 | 06:35 PM
madcossy's Avatar
madcossy
cool its being set up on rollers this week will get it checked then thanks
Old May 18, 2008 | 06:44 PM
JTECH James
Passion for Fords!
is it ok when hot?
Old May 18, 2008 | 08:00 PM
madcossy's Avatar
madcossy
is it ok when hot?
yes its fine with the iscv on when warm but if i come to a stop sometimes it it will rev hight but as soon as i unplug the iscv its all good
Old May 18, 2008 | 08:19 PM
JTECH James
Passion for Fords!
yeah prob tps....
Old May 19, 2008 | 05:01 AM
Or a crappy chip, my EA chip did that anywhere between 1200-1500rpm when warm, now with GGR chip back in due to problems wiht EA one it is rock steady at 900rpm.
Mind you the AFR was 10.5 on the EA chip!!
Old May 19, 2008 | 03:32 PM
madcossy's Avatar
madcossy
i have got an ea chip but it was doing this before i had the chip fitted someone told me there is a relay that causes this aswell anyone else heard this or know where the relay is
Old May 19, 2008 | 04:12 PM
Dan's Avatar
Dan
A common problem or so it seems!
When mine did this it was a dead ISCV, replaced it twice, once with a supposed brand new ISCV and I still had idle problems, replaced it with a second hand item and it's pretty sweet and well behaved now!
Where did you get your brand new ISCV from as they are no longer made I don't know of anyone who stocks them anymore!?
Old May 19, 2008 | 05:08 PM
NO relay involved with ISCV.
Old May 19, 2008 | 06:15 PM
madcossy's Avatar
madcossy
burtons about year ago they dont do them now but they still do the escort cossy do you know if they are the same iv tryed about 4 iscv and still the same
Old May 19, 2008 | 06:16 PM
madcossy's Avatar
madcossy
thanks
muffster
13
Sep 3, 2015 09:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Zoggon
Aug 10, 2015 10:39 AM
