Whos is the cheapest for ARP bolts??????
I need 3 kits all for a zetec
151-6005 Rods (9mm blacktop)
151-5404 Mains studs
251-4702 Head studs
And does anyone know if i could buy 4 Main studs and nuts that would match the 151-5406 kit??
reason being i need to fit the windage tray properly
Took the mian caps from a silver top so it would mount in the right place you can see its a longer bolt as the mains ar approx 23mm higher.
251-4702 Head studs
Right o thats just bought the bill down a bit im sure lol
Been looking and i found rod bolts on fleebay for Ł52 delivered but there only $49 in the usa hmmm Maybe ill get my mate to get them for me lol
Yeh i know i needs to be line bored if i use those caps when i actually run the engine its going off for a bottom rebuild so this was just for a line up so i knew how much spacer i needed.
On the other hand if the engine bloke says it's ok and not going to be a problem then ill leave it which i doubt so spacers are going to be made and the proper caps will be fitted.
my main caps: (on a cgi block)
larger pic:
http://kctuners.org/forum/uploads/12..._31_493740.jpg
larger pic:
http://kctuners.org/forum/uploads/12..._31_613879.jpg
larger pic:
larger pic:
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
