anyne got compression struts fitted on a road car
finally got to drive the car yesterday, although all the suspension is fitting against each other as i carnt get it set up until tuesday, i took it round the block
now every bump i can hear and feel every crack in the road lol
just wondering if this is normal due to haveing no bushes at the front now?
Sorry Tony , But i dont agree , Comp strut kit isnt good for road use ( they were never intended for road use ) without the ARB and TCA bushes it will be ar rough as hell ,
I had the kit fitted to one of my escosses and took it off after 2 days
Paul
Resident Wrestling Legend
martins got a car with this set up on a ramp, front mounted arb etc so the owner might be able to tell you how it drives
it will be harsh thats for sure, i've got it on mine but, to be honest, i can live with it
weather someone else can or not is the question
its all fitted correctly, but i carnt get it set up until tuesday anyhow so the car is staying in the garage until then
im running avo coilovers aswell, no front roll bar now
so will see what its like when its set up, there is no bushes either now bar the strut tops lol
think i found why its was crashing and banging
my front tyre was flat and only had 12psi in it
problem is the tyres dont look flat lol
so put some air in it and its so much better, yes ttheres still a couple of knocks when i hit a pot hole or something but other than that i think i can live with it
before it goes for set up im raising the ride height as its just far to low, for some reason while its been off the road its got lower
so this is being done asap, and hopefully it will all be ok again
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
