what head?
Old Apr 25, 2008 | 04:42 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default what head?
going to get my head gasflowed for the new T4 engine,
at the moment im heading CNCs way,
anyone recommend anyone?
want this sorted asap...so it can be mapped
Old Apr 25, 2008 | 04:45 PM
Darren at DAMICO, 01953 717784.
He has all the bits to do a good job loads of years experience, a cossie die hard, has engine dynos etc etc, worth a chat.
Old Apr 25, 2008 | 04:48 PM
JTECH James
Passion for Fords!
are they flow tested?
Old Apr 25, 2008 | 04:50 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
been hearing CNC heads are not so good now Jim as gone back to sweden
Old Apr 25, 2008 | 04:54 PM
bigchez's Avatar
bigchez
speak to karl at nms
JTECH James
Passion for Fords!
ahhh, maybe its a good thing i asked then....
Old Apr 25, 2008 | 04:56 PM
J1mbo's Avatar
J1mbo
B1mbo
someone who does it by hand is what you want i think scs does them any size might be worth a bell
Old Apr 25, 2008 | 05:00 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
ask ur tuner..........but nms will do a stage 2 head (supplied) for 750 + the twat....give karl a pm
Old Apr 25, 2008 | 05:14 PM
G2RSR's Avatar
G2RSR
Bodybuilding
Thinking about it you could try guy croft his books on performance engines go for something like £200 there so in demand so he must be doing something right
http://www.guy-croft.com/index.php
Tell him the spec of the engine and what its intended for
Old Apr 25, 2008 | 05:17 PM
JTECH James
Passion for Fords!
thanks guys keep the ideas comming!
i have asked my tuner,but this is an interesting topic...
Old Apr 25, 2008 | 05:48 PM
pete mcrash
other thing to price up if needed.....cams (of ur choice).....iskeys,new valves,seals,gaskets,etc...........
Old Apr 25, 2008 | 05:49 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i'll do it for a few hundred!
Old Apr 25, 2008 | 05:50 PM
JTECH James
Passion for Fords!
will be having all that...and the rest of the engine
Old Apr 25, 2008 | 09:25 PM
col cos1's Avatar
col cos1
im having issues with my head,il let you know if well known machine man dont sort it
Old Apr 25, 2008 | 09:40 PM
rapidcossie's Avatar
rapidcossie
The CNC heads are done by a computerised lathe so it makes no difference if someone has left or not.
Old Apr 26, 2008 | 12:07 AM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I used Andy Weston at Cylinder Head Developments. Always had a good reputation in years gone by, and lots of the big power Cossies seem to feature CHD work.
Old Apr 26, 2008 | 12:16 AM
Jim Green's Avatar
Jim Green
Karl Norris (NMS)........Very Well Respected and VERY Experienced.
Old Apr 26, 2008 | 04:42 AM
Yes Damico done by hand, every single one, all his heads work as confirmed by his testing results.
Old Apr 26, 2008 | 07:47 AM
big_wig_074's Avatar
big_wig_074
what a croc,a computer is only as good as its operator.
Old Apr 26, 2008 | 08:34 AM
Miller 3's Avatar
Miller 3
What' how can you get it wrong? its a CNC machine ? they will all come out exactly the same
Old Apr 26, 2008 | 08:36 AM
Slevin Kelevra's Avatar
Slevin Kelevra
unless the new employee gets to play with the program (which i doubt) then ur wrong mate
miller beat me too it!
Old Apr 26, 2008 | 08:38 AM
big_wig_074
unless you want some specifically for YOUR engine,custom work from someone who KNOWS what they are doing,not a machine that religiously follows what is input to it.it might be EXACTLY the same,but if its not input correctly in the first place then it will all be EXACTLY wrong!
and youre also saying a CNC machine never does anything wrong?hmmm.....well the scrap metal bins outside metal workshops around the country will disagree with you.
Old Apr 26, 2008 | 08:39 AM
Miller 3's Avatar
Miller 3
Old Apr 26, 2008 | 09:00 AM
Garage19's Avatar
Garage19
How can you develop a cylinder head without a flow bench, engine dyno?
So if you apply that rule neither Karl Norris or Cylinder Head Developments have either!
And how on earth do you think a hand ported head is preferable over a CNC cut one??? As long as the port shape is good the CNC is best every time as it can replicate that port shape precisly in every port with no variation time and time again.
Old Apr 26, 2008 | 09:12 AM
JTECH James
Passion for Fords!
thats what i thought! and i know the likes of cnc heads cut a few heads up to see exactly where they cant,and cant machine...
Old Apr 26, 2008 | 01:30 PM
G2RSR's Avatar
G2RSR
Bodybuilding
The main problem i heard is Jim used to do everything with the heads the development the computer putting the head onto the CNC machine Jim took great care that everything was 200% spot on
If your 1 mm out when bolting the head into place the whole head will be done wrong
Old Apr 26, 2008 | 01:43 PM
JonnyBravo's Avatar
JonnyBravo
The CNC heads make a good base but I think most people still have them fettled after which is a good enough reason not to use them.
Nik Waples, Karl Norris, Neil Roper are a few I can think of who I would use.
Old Apr 26, 2008 | 01:44 PM
JonnyBravo's Avatar
JonnyBravo
Never mind 1mm mate, if your a few thou out its gonna be wrong
I would imagine whoever does the cnc stuff there is capable of bolting things down in the right place
Old Apr 28, 2008 | 08:27 PM
JTECH James
Passion for Fords!
ordered a cnc one, with hand finishing today
Old Apr 28, 2008 | 08:28 PM
rapidcossie
good choice IMO!
Old Apr 28, 2008 | 08:30 PM
JTECH James
Passion for Fords!
lets hope so....should make proper power this time!
Old Apr 28, 2008 | 08:46 PM
timster's Avatar
timster
[QUOTE=G2RSR;3255637]The main problem i heard is Jim used to do everything with the heads the development the computer putting the head onto the CNC machine Jim took great care that everything was 200% spot on
If your 1 mm out when bolting the head into place the whole head will be done wrong [/QUOT
Use a probe like,should come with the cnc miller can programme it to measure the head every time you bolt/unbolt it
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
