remote I.S.C.V.
remote I.S.C.V.
Hi,does anybody know where i can get a remote idle speed control valve holder from?
basically used to hold the standard cossie item instead of it being mounted to the throttle body.
i have seen one on ebay before but not since.
Also does anybody know if these t.b.'s can be used with cossie management-
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=014
The above valve is part number 3717000102.
Webber, have two different housings listed, look on thier site and down load a PDF file with them all in.
Alternatively vauxhall use remote mounted ones on some of thier cars, that have a simple 1/2" in out pipe arrangement.
The throttle housing will work if you can get it to fit, just a case of getting a right way reading tps on there, of if going aftermarket ecu any way reading tps.
Perfect, the 1 under that part no. looks good.
I was looking at the throttle body and as you say the two(t/b,tps) pivot in different directions and as far as im aware the cossie management cannot be used with any other tps.i think i can still make it fit tho,
really helpfull,cheers
James Porter
28-10-2015 12:17 PM
