mfi boost problems?
Old Apr 18, 2008 | 06:55 PM
rst in breaking's Avatar
rst in breaking
Default mfi boost problems?
my mates escort turbo has a problem boosting, he removed the turbo and after refitting it he says he has no boost? it sounds like the turbo is spinning but not boosting above zero? am i right in thinking if it was a boost leak mfi wouldnt run or am i wrong? thanks guys
Old Apr 18, 2008 | 08:16 PM
GUZZLER's Avatar
GUZZLER
make sure the wastgate isnt siezed, also has he tensioned the actuator? thats a comon mistake.
Old Apr 18, 2008 | 09:28 PM
rst in breaking
he's fitted the same turbo back, and was only came off and went straight back on so shouldnt sieze and you can see it moving, will mfi run with a boost leak?
Old Apr 18, 2008 | 09:29 PM
rst in breaking
he changed his intercooler and just wondering if it has a poss pin hole or something if this would cause this?
Old Apr 18, 2008 | 09:35 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Check for boost leaks then, go over all hoses and check there all done up etc
MFi would still work too.
Old Apr 19, 2008 | 08:21 AM
rst in breaking
cheers rad
Old Apr 19, 2008 | 08:44 AM
mick_rst's Avatar
mick_rst
Slap Head
mfi would struggle actually if it was a noticeable boost leak as it runs on vacuum, so it hates any kind of air leak!!!
Sounds more like the wastegate to me!!!
Old Apr 20, 2008 | 10:26 PM
rst in breaking
turned out to be a dodgy intercooler , cheers
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
stevierob
Sep 7, 2015 07:09 PM
