R5 GT turbo prob
Yeah its a 5 but its a fuel pump issue so nothing weird and wonderfull.
Been at it a while now, basically whats happening is the fuel pump is getting good live and earth but nothing comes of it, so, i replaced the pump and all is well for around 2 miles then it conked out. Same again live and earth but no fuel, i even fed a new live and earth but the pump just flicks, its as tho it has jammed. Can anyone help....
Ta
Ta
Well i bypassed relay running a live and earth from battery, Im thinking must be a blockage in the pump via shit in the tank...
Thought the relay was next to fuse box, or is that the bulk head...
The fuel pump relay is under the dash on the passenger side. Had a gt turbo about 8 years ago and i just used to leave that relay dangling into the footwell so i could get to it easily when it played up (which was a lot!!)
What are you measuring the current with ?
If it is a digi metre or a test light, it could well be a bad connection/corrroded wire that is plenty enough to sugest no problems but not man enough to pass the current needed for the pump.
JK12
33
26-04-2021 12:09 PM
