water cooled PAS fluid resevior
25-03-2008, 09:21 PM
r they any good or just a gimmick??? im goin 2b doin a few trackdays and dont want brake fluid getting to hot
25-03-2008, 09:25 PM
Not a clue, but i've got one on mine!
26-03-2008, 10:56 PM
26-03-2008, 11:02 PM
DEYTUKURJERBS
brake fluid getting too hot? you said a PAS resovoir? or that a typo?
27-03-2008, 12:01 AM
my bad! i mean power steering
27-03-2008, 12:08 AM
Caraholic
100% needed on a Cossie track car - power-steering fluid over-heats and is blown out the header cap otherwise.
27-03-2008, 12:31 AM
Doesn't need to be water cooled. Easy enough to knock up the pipework to run through a nice oil cooler on the return line.
PAS is air cooled already!
27-03-2008, 08:19 AM
Quote:
Originally Posted by
Mike Rainbird
Even the original press cars suffered from it a lot during performance testing - esp on the high speed or twisty bits
27-03-2008, 08:25 AM
RichardPON
Most cars run a simple loop of tubing in front of the rads to this effect...
Very easy to knock up
27-03-2008, 10:16 AM
DEYTUKURJERBS
AlexF
Yup, Skylines have it as standard. I cut mine off when removing the aircon once by accident, wounder
27-03-2008, 10:19 AM
Mike Rainbird
Mine seems to bubble anyway!
Do you supply these Mike?
27-03-2008, 10:22 AM
AlexF
Cossies have it already - long loop of tubing running down the inside of the front chassis rail.
Obviously not hugely efficient, so as before, just plumb a cooler matrix in line.....
27-03-2008, 08:51 PM
Caraholic
Yes, both Spec-R and Pro-alloy
. Alternatively you can do it with a small oil cooler like the works cars, which is more efficient, but has packaging issues (see the front of Harvey's track car in the resto section which has coolers for everything)
- as in do you have room for this in an area that can provide airflow without blocking the cooling of something else?
27-03-2008, 09:07 PM
pas cooler
just get a cooler from a breakers yard jag diff cooler or some jap stuff has coolers for pas here is a pic of mine
27-03-2008, 09:27 PM
Former Sponsor
2b?????
text speak should be banned on here!!!
Mark RS
12-10-2015 06:01 AM
DAZZER
30-09-2015 08:43 PM
SMILER258
28-09-2015 09:04 AM
