Couple of GT30 Q's
23-03-2008, 09:56 PM
Monte Geek
Couple of GT30 Q's
Are they water cooled?
Do you need to run a dump valve/re-circ with them?
Do the 4x4 head Spec-R dampers and original T4 dampers fit them or is it the Bailey style only??
What size pipes do they use? 102mm inlet? and outlet??
Thanks
23-03-2008, 09:57 PM
Yes to all 4 should i say bailey modded damper
edit cause pissed
23-03-2008, 10:00 PM
1st to 200 without NOS
For once in Phil's life he is correct ..The missing info is.. inlet 102mm / outlet 63mm
23-03-2008, 10:04 PM
Monte Geek
So the Spec-R damper with T4 damper will fit?
23-03-2008, 10:06 PM
..no you need the bailey modded from my experience!
23-03-2008, 10:10 PM
Quote:
Originally Posted by
Paul Ripley
Maybe but we never use them.. Bailey in stock and ready to go!!
23-03-2008, 10:12 PM
Lukesville
Oil restrictor needed to i think, didnt come with it you have any in Martin.
Monte Geek
Thanks Phil/Martin
Martin forget to phone you friday did you find the missing parcel? How much are the dampers?
23-03-2008, 10:15 PM
m4dyeti
Yes in stock...
23-03-2008, 10:16 PM
Lukesville
Speak to you tuesday then Martin
tankybaby66
06-02-2016 02:24 PM
gingeRS
17
02-10-2015 09:42 AM
Fudgey
21
30-09-2015 06:19 PM
deathrider666
28-09-2015 06:12 PM
