lc-1 wideband question....
Boost Builder
is the analog output number 1 (0.10v-1.10v) the same scale of a standard narrowband ?? ie if i replaced a narrowband with wideband and used the output 1 connected to the signal wire to ecu so lc-1 wideband will be supplying ecu with readings for closed loop, is that right?????
cant write above to sound right but hopefully you will get me lol
You program it to whatever u like with the programer software, it has 2 analogue outputs, which u can set to anything u like. One of the software presets is narrow band simulation.
Boost Builder
cool so can run ecu signal for closed loop off the output on the lc-1 and bin the standard lambda?? saves me putting in a new boss and makes it a bit neater, cheers
Carlsworth
03-08-2006 12:29 AM
Jim Galbally
10-03-2006 12:17 AM
Jim Galbally
09-03-2006 09:49 PM
