zetec turbo
Lukesville
For 330 the Bosch green tops 450cc - (P/N 0280150558)
would be a sufficent but not big enough for 400hp.
Something like the Siemens 72lbs/hr 750cc/min (P/N 3145)
possibly may flow as low as 330 and will flow 400.
For 450hp im going with the Siemens 865cc 83lbs.
I ran the Bosch green tops at 230 on the cvh with emerald K3 ecu they ran fine (probably a little overkill for 230 mind you )
the problem with cvh and zetec they dont burn the fuel efficiently very poor VE i maxed out grens on my zvh 310hp @ 19psi so would definatly go bigger..
sean
sean
