Replacing driven wheel bearings
Old Feb 19, 2008 | 07:12 PM
Cossiep's Avatar
Cossiep
Default Replacing driven wheel bearings
Guys,
How much agro is it to replace wheel bearings on the driven wheels ? car in question is a w210 merc e280
Been googling and found all kinds of stuff, many topics saying it's too difficult and special tools are required to remove driveshafts etc
Local independant wants nearly £400 which I thought was steep ?
I replaced the front myself recently with no probs but I'm led to believe the driven wheel on most cars are a lot more difficult...............
Opinions please
Old Feb 19, 2008 | 07:23 PM
Mark_'s Avatar
Mark_
the usaual route is to remove and replace bearing with a hydrolic press as the are difficult to remove without one. they can also be tricky to replace as your not meant to tap the bearing into place as it could damage it. you can make a make shift tool using a long bolt and some big washers and a relivant size tube to wind the bearing into position as i have done on my rs2k 4x4 before. just depends weather you are confident enough to give it ago. my drive shafts were easy to remove, undo the lower arm balljoint pinch bolt, seperate the balljoint from the hub, undone the center nut and gave it a tap and it poped out. not sure if thats the case on your r/w/d merc. not sure if you would have half shafts or drive shafts on it.
malkiemac3579
Jul 14, 2017 12:10 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
rst-s1
Aug 23, 2015 07:56 AM
muz
Aug 1, 2015 06:48 AM
