who sells sweedish inlets?
Old 08-02-2008, 10:13 PM
  #41
rapidcossie
rapidcossie's Avatar
show off
Old 08-02-2008, 10:14 PM
  #42
Fudgey
Baby Cheesus
Fudgey's Avatar
yep
Old 08-02-2008, 10:16 PM
  #43
JTECH James
Passion for Fords!
JTECH James's Avatar
vaccum pipes on the bottom dan......they will end up full of oil, and fills your map sensor up...
would be soo much better with them moved up a bit, even 10mm, so they are out of the oil.
i got fed up with pulling vaccum pipes of and it dripping oil on the floor, and had a map sensor fail due to being full of oil....
strangly my engine used no oil at all, and i was using your 247 turbo which was mint, so it happens.....
Old 08-02-2008, 10:18 PM
  #44
Fudgey
Baby Cheesus
Fudgey's Avatar
except it wont
im using roller barrels so i need all the vac/map/als take offs after the throttles lol
so them ones will be blocked bar the air temp sensor in the big hole
Old 08-02-2008, 10:21 PM
  #45
JTECH James
Passion for Fords!
phew...thats all good then mate!
just one question, if it was custom built for you, why did he put them on there?
Old 08-02-2008, 10:22 PM
  #46
Fudgey
Baby Cheesus
Fudgey's Avatar
yeah, its all thought out mate - just implimenting it thats the pain in the ass
Old 08-02-2008, 10:23 PM
  #47
rapidcossie
I have had my inlet off a few times and never seen oil inside it?
How can there be oil inside it unless your breather is recircing back into airbox?
Old 08-02-2008, 10:26 PM
  #48
JTECH James
Passion for Fords!
probably to do with running a t34.48 at 35psi dan just looked at the pics properly, i can see the roller barrels now, i really should have looked first
Old 08-02-2008, 10:27 PM
  #49
rapidcossie
killing the turbo seals and letting oil into the cooler and then thru into the inlet?..
Old 08-02-2008, 10:28 PM
  #50
JTECH James
Passion for Fords!
my breather didnt go back into the air box, it must have come from the turbo i guess, it did it on both of mine, both new aswell. not alot of oil, just a trace, but it always ended up in the vacum pipes, which really gripped my shit
Old 08-02-2008, 10:31 PM
  #51
JTECH James
Passion for Fords!
ive heard a few other peps having the same problem too....not just me for once
Old 08-02-2008, 10:35 PM
  #52
Jay,
Sponsor
Jay,'s Avatar
heres mine from garage 19 and very good price
Old 08-02-2008, 10:40 PM
  #53
mk3cosworth
mk3cosworth's Avatar
got mine off ian howell with 80mm throttle
  #54
Fudgey
Baby Cheesus
Fudgey's Avatar
why?
cos i told him to make the reverse of a cossie one, and forgot to say not to put them on there lol
Old 08-02-2008, 10:42 PM
  #55
mk3cosworth
my pipes aer on the bottom, ill check for oil i reckon
Old 08-02-2008, 10:45 PM
  #56
Jay,
Sponsor
Jay,'s Avatar
garage19 fits them at the backof the inlet
Old 08-02-2008, 10:48 PM
  #57
mk3cosworth
ye just seen that, but if thers oil in there it will go down them werever they are wont they under the pressure, what you reckon
Old 08-02-2008, 10:50 PM
  #58
Jay,
Sponsor
Jay,'s Avatar
well i have used the top hole on the rear for the map sensor but i believe thats where the mike r ones are mate
Old 08-02-2008, 10:53 PM
  #59
mk3cosworth
just rememberd my map sensors higher up than the manifold, top of inner wing near battery lol
Old 08-02-2008, 10:56 PM
  #60
JTECH James
Passion for Fords!
the oil tends to gather at the bottom,at least when the engine is stopped.
then it fills the pipes up.
mike r ones have a single outlet on the rear like jays,which feeds a remote unit which the pipes connect to.act is underneath still.
Old 08-02-2008, 10:59 PM
  #61
JTECH James
Passion for Fords!
your pipe could still gather oil at the lowest point,worth pulling the pipe off to make sure nothing comes out....
Old 08-02-2008, 11:00 PM
  #62
mk3cosworth
ye will do
Old 08-02-2008, 11:15 PM
  #63
NEIL A
NEIL A's Avatar
So what is your comp Euan , even lower than 7.2
Here is a few of mine, cant comment on the effects yet as the car is on a rough running in map, but will be fitting a remote idle speed control valve.
Old 08-02-2008, 11:42 PM
  #64
BigErn
BigErn's Avatar
I know comp on a couple of cars on here are in the high 6's mate.
Old 09-02-2008, 12:55 AM
  #65
NEIL A
NEIL A's Avatar
High 6's
Old 09-02-2008, 08:44 AM
  #66
JTECH James
Passion for Fords!
cols is 6.9
Old 09-02-2008, 11:18 AM
  #67
col cos1
col cos1's Avatar
mine is 6.9.0 and euans is even lower than that
is anyone going to tell me how to get in touch with this garage19
pmd sib no reply yet
il be needing to get my car mapped anyway euan as new head,injectors etc
Old 09-02-2008, 11:27 AM
  #68
Taylor
Taylor's Avatar
I have no probs with low down power with one.
Al vouch for that mate lol!
Old 09-02-2008, 11:38 AM
  #69
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
Send Doug a PM is the best way - sure Garage19 is his actual user name.
I'll PM you now with some info.
Si
Old 09-02-2008, 11:48 AM
  #70
Jay,
Sponsor
Jay,'s Avatar
garage 19 is away for 3 weeks col so if you cant wait then go sib's route as he will sort ut out , the workmsnship on his stuff a very good standard
Old 09-02-2008, 12:10 PM
  #71
rapidcossie
mine is pretty low.....lower than 7:1 anyway....
It might in fact be too low
Old 09-02-2008, 12:37 PM
  #72
Steven_RW
Steven_RW's Avatar
Col Cos 1 why not just call Mike? - he is one of the lads
RW
Old 09-02-2008, 12:54 PM
  #73
Fudgey
Baby Cheesus
Fudgey's Avatar
was just gonna say doug is on holiday for 3 weeks now the lucky git lol
Old 09-02-2008, 12:55 PM
  #74
Jay,
Sponsor
Jay,'s Avatar
yeh bastard newzealand and LA
Old 09-02-2008, 05:07 PM
  #75
col cos1
col cos1's Avatar
RW
cause im a tight kent,and im not really into spending Ł300 on 1
i appreciate it takes a while to make 1 but once theres a mould to work from surely when mass produced theyd come down in price it is only a box section of stainless steel afterall
Old 09-02-2008, 05:14 PM
  #76
JTECH James
Passion for Fords!
r+b ones are alloy...
Old 09-02-2008, 05:23 PM
  #77
Alps Pacino
Alps Pacino's Avatar
col cos1
Your not doing the jocks any favours in proving there not tight cunts
Old 09-02-2008, 05:26 PM
  #78
col cos1
col cos1's Avatar
even more reason for them to cost less
Old 09-02-2008, 05:27 PM
  #79
col cos1
col cos1's Avatar
Originally Posted by Alps Pacino
col cos1
spending 30k on a car that done 1500miles in 2 years i suppose im not that tight then
Old 09-02-2008, 05:32 PM
  #80
abdr500
abdr500's Avatar
ok so i gess the mike rainbird ones are made to perfection rather than some bent over untested one are any of these tested
Quick Reply: who sells sweedish inlets?
