which long stud kit?
Old Feb 5, 2008 | 06:01 PM
col cos1's Avatar
col cos1
Default which long stud kit?
im running mountune just now but with the new head going on ............
i just remembered that when we fitted them first time round i had to have the machine shop machine holes to fit the skinniest snap on socket in
and obviously id rather not have to do this this time if it can be helped
Old Feb 5, 2008 | 06:53 PM
rapidcossie's Avatar
rapidcossie
Speak to Alan Col...there are better ones avail than the Mountune ones
Old Feb 5, 2008 | 07:13 PM
col cos1's Avatar
col cos1
cheers euan but do they need to have head machined to get socket in?
Old Feb 5, 2008 | 07:14 PM
rapidcossie
Not sure?
On mine you have to take the cams out but dont think the head has been machined?
Old Feb 5, 2008 | 08:47 PM
jaimesdna's Avatar
jaimesdna
i'd also like to know this. who is alan & what sort of price is normal. i reciently had one snap inside the block. still gotta get it removed
Old Feb 5, 2008 | 08:49 PM
rapidcossie
Alan owns and runs AVA.
Mike Rainbird can sort you out with the long stud kit Im on about, its of a higher quailty than the Mountune ones.
Old Feb 7, 2008 | 10:15 AM
NEIL A's Avatar
NEIL A
Got shown the difference between the mountune and the new style of head bolts yesterday. The new style are a good bit thicker on the second half of the stud and also have a finer thread. Alan said because of the finer thread they use a smaller nut meaning the head doesnt need modded.
Old Feb 7, 2008 | 10:21 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
how much are they?
Old Feb 7, 2008 | 10:25 AM
NEIL A's Avatar
NEIL A
Give Mike R or AVA a phone they will be able to give you a price
Old Feb 7, 2008 | 10:32 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
I keep these on the shelf but they differ from the Mountune type studs in that the machined recesses in the deck face are a smaller diameter which avoids breaking into the oil gallery, the fastening nuts are 17mm too which helps. These are obviously no good if your block is already machined for the larger diameter type.
Old Feb 7, 2008 | 11:34 AM
JTECH James
Passion for Fords!
where near devon can do the machine work to the block? anyone know anywhere?
Old Sep 4, 2008 | 07:03 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Anyone got news regarding long studs "better than Mountune ones" ? I have seen both Mike and Martin are selling some, but is there another company ?
Old Sep 4, 2008 | 07:06 PM
J1mbo's Avatar
J1mbo
B1mbo
machine down a socket dont machine the head
J1mbo's Avatar
J1mbo
B1mbo
numbers in the sig buddy
Old Sep 4, 2008 | 07:11 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
As Jimbo sais, machined socket is far easier than a machined head lol
Old Sep 4, 2008 | 07:36 PM
J1mbo's Avatar
J1mbo
B1mbo
if i amreading correct and tirednesss isnt taking over but am i really reading the heads were machined !!
is it not common sence !! it wud cost ya a fived to machine down a socket !! and a bomb i guess to machine the head !!
Old Sep 4, 2008 | 07:48 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Got a price range mate btw ?
Old Sep 4, 2008 | 07:49 PM
J1mbo's Avatar
J1mbo
B1mbo
no sorry dont know off the top of my head
give us a ring 2morow some time and the ol fella can sort ya out !!
6stud and 10 stud of course
Old Sep 4, 2008 | 07:50 PM
Mark Shead's Avatar
Mark Shead
Some early 2wd heads had a smaller bolt hole in the head so these need machining for the machined socket to fit.
Mark
Old Sep 4, 2008 | 07:51 PM
col cos1's Avatar
col cos1
just to clear this up you can only machine a socket if useing a late 2wd or 4x4 head,the recess for 3-door head is much smaller and smaller washer
i had 2 sockets machined down and tried them and there was no danger they were getting in the hole
Old Sep 4, 2008 | 07:52 PM
J1mbo's Avatar
J1mbo
B1mbo
Mark
we use one socket for any head with longstuds iirc
jim
col cos1's Avatar
col cos1
beat me to it mark lol
col cos1's Avatar
col cos1
jim
must be a box socket jim
Old Sep 4, 2008 | 07:54 PM
J1mbo's Avatar
J1mbo
B1mbo
i dont even know wat that is lmao
Old Sep 4, 2008 | 07:56 PM
col cos1's Avatar
col cos1
box spanner i think they are called,thin as fuck,you couldnt use one for accurate torque settings
Old Sep 4, 2008 | 07:58 PM
J1mbo's Avatar
J1mbo
B1mbo
oh right
Old Sep 4, 2008 | 08:00 PM
vroooom ptssssh
It Wasnt Me!
never had a prob gettin a machined socket down, jus sometimes had to machine it smaller lol not every socket fits even if machined though!
Old Sep 4, 2008 | 08:06 PM
col cos1's Avatar
col cos1
i got a single hex and a double hex done and they were so thin it was unreal,if you tapped them it sounded like a tin box,and neither fitted by a long shot
£60 later the head was opened up
Old Sep 4, 2008 | 08:11 PM
Mark Shead's Avatar
Mark Shead
Yep, you had the head with the small holes.
Mark
Old Sep 4, 2008 | 10:32 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
p mason engineering in maldon, essex did mine, i think it was £240ish for machining and studs, they looked descent quality too.
Old Oct 20, 2008 | 08:59 AM
Stuart.W's Avatar
Stuart.W
Are these not 100% identical to the Mountune ones as I was told they used the same part between them, this was many years ago when I bought mine so not sure if anything has changed since?
Old Oct 20, 2008 | 09:19 AM
Stuart.W's Avatar
Stuart.W
I intend to insert steel rings (loctite sealed) into my block deck to use the smaller diameter O ringed long studs you mention.
Would be nice if the main supplier got them made in the larger diameter to save the hassle.
jessie_rs
62
Aug 6, 2019 09:27 PM
jonfoc
16
Sep 11, 2018 05:35 PM
coscor86
Sep 20, 2015 01:21 PM
Bailes1992
Sep 19, 2015 02:17 PM
roomey
Sep 19, 2015 08:40 AM
