YB Engine Problem - With Both Compression Results - UPDATE
Old Jan 30, 2008 | 05:21 PM
Ryan's Avatar
Ryan
Default YB Engine Problem - With Both Compression Results - UPDATE
Right quick story.
Engine has been sat unrun for about 2-3 months over crimbo. (Engine ran faultless before going away for christmas)
I decided to do a compression test just out of interest.
and found that Number 4 has 7bar of pressure, 5 bar below all the other 3.
I've done a wet compression test, and this didnt change the result so i think thats rules out a stuck piston ring.
After speak to diva, he said he has had it before where a tappet has become solid and doesnt allow the valve to shut properly. COuld this be the case. I've tried putting a feeling gauge under the cam/tappet area and alot of them i cant feed the gauge in (all 4 on the number 4) some i can move up and down slightly with my fingers but other i cant. (obviously i move the cams/belt round so the lobes are at dwell.
Could this have bent or chipped my valve?
Any other test to do or suggestions before i take the head off
Old Jan 30, 2008 | 05:24 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Be worth doing a leakdown test before speculating on possible damage
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: YB Engine Problem
Originally Posted by Ryan
Right quick story.
Do a leak down test with the cams loosened off..
Edited to say..Beaten to it by a few seconds
Old Jan 30, 2008 | 05:26 PM
Ryan's Avatar
Ryan
right being a bit of a novice what is needed for a leak down test? as obviously the car is now static
Old Jan 30, 2008 | 05:27 PM
Ryan's Avatar
Ryan
rocker cover is already off and so is inlet as these were already being changed at the time.
If that makes life easier, or does it make it impossilbe to do a leak down with these off?
Old Jan 30, 2008 | 05:35 PM
Martin-Hadland
You will need a leak down tester and a compressor, if you don't have the facilities maybe a local place might be able to do it. I can but I'm hardly local!!
Old Jan 30, 2008 | 05:37 PM
Big Will_'s Avatar
Big Will_
Leak down test is basically putting a threaded extension (bit like your compression tester) into the spark plug hole and then pressuring the cylinder with compressed air from your handy household compressor
(Not sure if you have access to an airline or not)
The leakdown test will basically show how much of a measured pressure is lost.
You can listen to where the air is escaping by listening either at the inlet or at the exhaust tailpipe - or through the oil filler cap if you have serious issues
Old Jan 30, 2008 | 05:38 PM
Ryan's Avatar
Ryan
that rules that out then
Old Jan 30, 2008 | 05:56 PM
Ryan's Avatar
Ryan
is there anything i can do with you average tool? i.e no compressor.
i.e test tappets/clearances etc etc
Old Jan 30, 2008 | 06:27 PM
markk's Avatar
markk
remove the cams and belt and then do a compression test, althoguh the figures will be low, they should all be near equal
Old Jan 30, 2008 | 06:32 PM
Ryan's Avatar
Ryan
what will this prove mark? i.e above cranking it normally, i.e obviously valves wont open, but if there not shutting properly in the 1st place its not changing anything? or you mean it will illiminate the HG?
sorry to sounds like a tit
Old Jan 30, 2008 | 06:37 PM
markk's Avatar
markk
if your lifters are staying open i.e they have jacked, then this will keep the valve open no matter what the cam does, by removing the cams it will free off the lifters to do what they want !
although the readings will be low, as to build compression you need to get air into the cylinders, without the cams the valves should stay shut, so on a good engine the figure will be low, but equal.
a leak doen is the easiest way tbh, but if you havent got one !
Old Jan 30, 2008 | 06:40 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Ryan
I bet now you are cursing yourself now for doing a comp test for no reason mate. If nothing was wrong the last time you switched it off then how could anything major happen?
Old Jan 30, 2008 | 07:13 PM
Ryan's Avatar
Ryan
i know mate, your telling me.
mark yeah i might give that a go tonight.
Old Jan 30, 2008 | 07:14 PM
JonnyBravo's Avatar
JonnyBravo
Get out there and do it now ! atleast you will stop worrying.
Old Jan 30, 2008 | 07:15 PM
Ryan's Avatar
Ryan
right off to the garage now.
back in 20 mins with the results
and possibly the bad or good news.
Old Jan 30, 2008 | 07:19 PM
Stu @ M Developments's Avatar
PassionFords Creator
Will you should be here by now, the film starts in 26mins and we need to que for ice cream.
Old Jan 30, 2008 | 07:30 PM
Dan's Avatar
Dan
Nicole hogging the kitchen Stu or you at the cinema?
What ya gone to see mate?
Sure everything will be fine Ryan, stop worrying!
Old Jan 30, 2008 | 07:44 PM
Ryan's Avatar
Ryan
right just done what mark suggested and now i'm even more worried
Measured in BAR
1 = 7.8
2 = 6.5
3 = 4.0
4 = 3.0
here's the weird thing, No 3 is very low and when i did the comp test normally, No 3 was the highest reading
Here are the normal comp test readings:
1 = 12.0
2 = 11.5
3 = 12.5
4 = 7.5
Old Jan 30, 2008 | 07:51 PM
JonnyBravo's Avatar
JonnyBravo
Its going somewhere mate
Cams are fully out I take it ?
Old Jan 30, 2008 | 07:52 PM
Ryan's Avatar
Ryan
yes cams are out mate, there sat on the bench, tappets are still in but im sure the weight of a tappet isnt going to affect anything.
i really do wonder why i started
Old Jan 30, 2008 | 08:00 PM
dave cos4x4's Avatar
dave cos4x4
what about getting it running again,taking it for a little run etc....and getting it checked out.
was it running ok etc....before.
Old Jan 30, 2008 | 08:01 PM
rapidcossie's Avatar
rapidcossie
Dont get to disheartend until its checked by an expert Ryan.
These tests are quite sensitive to the way in which they are carried out and if this is the first time you have done them there is no telling if you are doing them 100% correctly.
Old Jan 30, 2008 | 08:07 PM
Ryan's Avatar
Ryan
dont know euan, pretty sure im doing it right.
im loosing the will to live with this fucking 3dr, nothing is ever simple with it, it was easier building my old one, think its trying to tell me something
Old Jan 30, 2008 | 08:09 PM
JonnyBravo's Avatar
JonnyBravo
Break it
Old Jan 30, 2008 | 08:10 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
ryan if you have a compressor, i will overnight you my leak down tester tomorrow, so you can see where the leak is....
Old Jan 30, 2008 | 08:16 PM
Ryan's Avatar
Ryan
cheers for the offer, but i dont have a compressor
Old Jan 30, 2008 | 08:21 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
If it was running cool why did you check it and start all this worry
Old Jan 30, 2008 | 08:25 PM
IANS2RST's Avatar
IANS2RST
a stone cold engine will give unusual results, the amount of oil in the lifters & how the engine internals expand with heat will affect the results.
get it running then check again
Old Jan 30, 2008 | 08:30 PM
marco polo's Avatar
marco polo
ryan
just run it and do the test after if it was ok before then it should be ok
Old Jan 30, 2008 | 08:38 PM
PAUL V's Avatar
PAUL V
What make of gauge are you useing ? is the battery full charged up when doing the test ?
Also got to ask with the cams out where does the air come from to be compressed Ie no inlet cam to open the valve ?
Old Jan 30, 2008 | 08:40 PM
JTECH James
Passion for Fords!
thats why the reading are very low with the cams out.......
but they should still be even
Old Jan 30, 2008 | 08:48 PM
Ryan's Avatar
Ryan
battery was fully charged.
think the gauge is a halford/motor factors item, cant remember the name off hand.
Old Jan 30, 2008 | 09:15 PM
PAUL V's Avatar
PAUL V
Had one of my customers with a Low comp reading he moaned and moaned about the piston i has supplyed him, turned out to be the gauge.
Would try another gauge if i was you
Old Jan 30, 2008 | 09:17 PM
Ryan's Avatar
Ryan
yeah thats what i think im going to do tommorrow.
jsut to be on the safe side.
I've got a grpA head gasket and bolts coming tomorrow, but its obviously the last thing i want to be doing, but its not the end of the world
fucking feels like it though
Old Jan 30, 2008 | 09:20 PM
glancy2081's Avatar
glancy2081
are you cranking it over the same amount of time each time,stupid question i know but seen this give different readings if cranking it over more on some cylinders
Old Jan 30, 2008 | 11:14 PM
Ryan's Avatar
Ryan
yes mate, i do it till the needle on the gauge stops jumping.
Anymore suggestions?
Old Jan 30, 2008 | 11:21 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Measured in BAR
1 = 7.8
2 = 6.5
3 = 4.0
4 = 3.0
1 = 12.0
2 = 11.5
3 = 12.5
4 = 7.5
Try that test again, I reckon number 1 will be lower now
Old Jan 30, 2008 | 11:23 PM
Ryan's Avatar
Ryan
chip, is that just common sense mate? or is there something that would make it have a high reading?
Old Jan 30, 2008 | 11:27 PM
Chip's Avatar
Chip
Try it mate, and see if its any lower now.
