Can a rev counter cause a misfire ?
RWD Racer
Can a rev counter cause a high speeed misfire ?
Talking pre 80's electrics here aswell, so no fandango modern digi stuff
Ever known it happen?
RWD Racer
Originally Posted by kjc300
Prob more than likely the item that sends the signal to the rev counter - bit like the ign amps were doing on my escos.
Tried diffo coil aswell as a brand new amp.
Just wondering if a rev counter can cause a fault?
Username change wanted!
Disconnect the feed to it and see if it still misfires, this is a common problem with stuff that uses an ignition amp, the rev counter usually isnt the problem, but lets you know the fault is eletrical rather than fuelling. probably..
What car is it?
What car is it?
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
