Engine damage pics from Yellow Audi ZR
Old 26-01-2008, 05:22 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Default Engine damage pics from Yellow Audi ZR
Mashed oil pump
Holes everywhere
Hole in my baffled sump
The culprit
Old 26-01-2008, 05:24 PM
Mixja
420
Mixja's Avatar
ouchy...
looks expensive....
JonnyBravo
JonnyBravo's Avatar
Yeee haaaaa
Proper job there Martin
Atleast you have a few bits to add to the collection.
When did it happen ?
Old 26-01-2008, 05:27 PM
Martin-Hadland
Originally Posted by JonnyBravo
Yeee haaaaa
Happened at Brands on a warming up lap, hopefully fixed in time for Bedford.
Old 26-01-2008, 05:30 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
Were they uprated rods or original ones? What sorta power were you running at the time?
Si
dojj
Resident Wrestling Legend
dojj's Avatar
Originally Posted by Mixja
ouchy...
looks expensive....
nah mate, it just looks fooked
the rods obviously let go but was it standard and what sort of revs were you doing when it went bang?
can't say i've seen a rod go like that before, i've only seen them pop at the big or little ends not just come aprat in the middle like tha tone seems to have
Old 26-01-2008, 05:35 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Nice mess
Hope its done for bedford
Martin-Hadland
Si
Std Rods with about 270hp and the max revs ever used were 7.5k, new donkey has h section rods
Old 26-01-2008, 06:00 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
lol ive done exactly the same to a cvh mopor in the rst ,
still got the the chunk of rod in the drawer as a reminder lol
way to go martoon
beef
Old 26-01-2008, 06:16 PM
Si B
Si B's Avatar
Si
We have a friend (Andy) who has a TT lump in his Lotus Elise, running 320-350bhp using a largely standard bottom end.
Just curious if you were pushing big power to get the rod to snap.
Would have thought 270bhp and normal revs would have been fine - freaky bad luck perhaps?
At least the new motor will have some harder internals! More boost and more power then!!!
Be good to see it at Bedford, want to see how a modest power FWD car with the right bits on it actually goes
Si
Old 26-01-2008, 06:30 PM
dave cos4x4
dave cos4x4's Avatar
done it proper Martin.
Old 26-01-2008, 06:35 PM
fezzajsy
fezzajsy's Avatar
Old 26-01-2008, 06:45 PM
AlexF
AlexF's Avatar
LOL @ modest power
Old 26-01-2008, 07:02 PM
leecavturbo
leecavturbo's Avatar
no ARP's fitted ?
Old 26-01-2008, 07:09 PM
Martin-Hadland
Originally Posted by leecavturbo
no ARP's fitted ?
Why would that have helped? The big end was still attached and the bearing was still mint!!
Old 26-01-2008, 07:11 PM
leecavturbo
no ARP's fitted ?
i see. it wouldn't then
Old 26-01-2008, 07:19 PM
Benni
Ban[B][/B]ned
Benni's Avatar
I love that car, I have dreampt of that being my track car.
Old 26-01-2008, 07:20 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
wounder!
as unfortunate as it is, im always interested to see engines that have let go lol
any ideas what caused it?
as i know of a few std audi motors making more power than that and still ok
i think wyane at pro-alloys elise with an audi engine was running circa 350bhp on std motor when it dropped a valve...
that was a mess!
Old 26-01-2008, 08:43 PM
Kelv
Almost there!
Kelv's Avatar
Ouch, poor little engine.
Fixed in no time im sure
Old 26-01-2008, 09:21 PM
Martyn
Martyn's Avatar
What engine is it?
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Not good
Taken the head out as well Martoon?
Old 26-01-2008, 09:26 PM
dojj
dojj's Avatar
he probably had a spare for them "just in case" moments sitting in the back of the motor anyway and more than likely spannered it into place and then carried on a few minutes later
those shots are probably from when he got home and took it apart during his tea break
Old 27-01-2008, 06:35 AM
Kelv
Almost there!
Kelv's Avatar
dojj, the worrying thing is your probably right
Old 27-01-2008, 06:57 AM
Bullett
Bullett's Avatar
thats mashed.im sure this isnt bad luck,its just fates way o saying why leave it standard when martin own it.its a come on get me modded knudge.
Old 27-01-2008, 09:48 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by Will @ M Developments
Not good
do you really need to ask that?
Whole thing must be fucked surely?
Luckily unlike cossies you can easily find a perfect condition head for these vag motors though luckily.
Good bit of carnage that martin, if you are going to fuck it, do it properly I reckon
New motor sounds interesting, what sort of power will it be?
Old 27-01-2008, 10:14 AM
Big Will_
Big Will_'s Avatar
Chip-3Door
Was curious
Most of it seems to have gone out the side of the block
Old 27-01-2008, 12:26 PM
dojj
dojj's Avatar
4th picture down shows the picton at the top of the cylinder, so it's either saved everything or it's fooked everything
i'd more than likley put money on it having fooked everything as it would have let go with a bit of speed
Old 27-01-2008, 02:25 PM
Martin-Hadland
I do have several spare engines, one of which has already been stripped/checked and re-assembled with special valves, big port head, h section rods, balanced bottom end , new flywheel and twin plate clutch. The damaged sump has slowed progress
Not good
It wasn't such a stupid question, the head is totally untouched.
Old 27-01-2008, 03:12 PM
Spiky
Spiky's Avatar
for chip then
Old 27-01-2008, 04:02 PM
Chip
Chip's Avatar
Certainly is, im amazed at that when the rod let go totally, must have been when the piston was on it way down
Old 27-01-2008, 04:22 PM
Dan
Dan's Avatar
Fook!
Old 27-01-2008, 05:08 PM
Tony Ryan
Tony Ryan's Avatar
sadly ive just sold the engine that might've helped but ive still got the shell if you fancy a project ! I believe these use the 4wd Floorpan from the TT so a 4wd Seat Cupra might be possible .
Old 27-01-2008, 05:11 PM
Martin-Hadland
Thanks but I'm looking to offload projects rather than take on more
Old 27-01-2008, 05:42 PM
richm
richm's Avatar
Tony - is that a Cupra Cup car?
Do you know what engine spec those Cup cars ran - power/rpm and inrternal components?
I believe they were around 250bhp and pretty much standard internals, including the rods, with baffled sump and paddle clutch. Do you know if this is accurate?
Old 27-01-2008, 05:45 PM
Tony Ryan
Tony Ryan's Avatar
yes, thats about right , i ran this one this season , great cars .
Old 27-01-2008, 06:24 PM
JonnyBravo
JonnyBravo's Avatar
Lucky with the head
I had a engine go off at 9k once and 3 rods left the block, understandably I assumed the head would of been totalled but that wasn't touched either.
I'm not quite sure how though
Old 27-01-2008, 06:37 PM
richm
richm's Avatar
chhers Tony
we bought one with a view to converting for the Castle Combe saloons championship this year, but was too bent to be worth reclaiming it turned out, so all the bits are going in a TT instead we need considerably more than 270bhp though, so will be following Martin's rebuild with interest
Old 27-01-2008, 10:17 PM
RickyLee53
RickyLee53's Avatar
In a turbo engine, surely it would always happen on the way down? (unless it's a high revving 1)
They snap/bend with torque, its rev's what send them the other way.
My Evo did the exact same and head was untouched.
However, my mates civic, 9500rpm rod failure. That heads been damaged slightly
Old 27-01-2008, 10:23 PM
AlexF
AlexF's Avatar
COUGH
Firenza??
COUGH
Old 27-01-2008, 11:16 PM
RONNIE AMIS
RONNIE AMIS's Avatar
Yeee haaaaa
right in front of me coming out of graham hill band
Quick Reply: Engine damage pics from Yellow Audi ZR
