Pug 205 carb'd running problem
Firstly, I know it's not a Ford, but is a lot of knowledge on here, hopefully covering old carb'd French shitbox's
Old 205 XS 1400, randomly backfires, could be once a mile, or not for 20 miles.
Had my toe down for a long time earlier, and it cut out.
When it cuts out or backfires, the rev counter stops working.
When power comes back, rev counter works.
Has had everything on spark side renewed, other than ignition amplifier - I'm sure it's an amplifier, coil is a module more than coil I'm familiar with.
I've adjusted the timing.
It seemed as if it was running out of petrol, but the backfires would suggest lack of spark, and fuel wouldn't effect the rev counter.
Seems as if heat is the issue - the times we broke down it would be ok after a few minutes.
Anyone any ideas? Got me stumped.
Think need to know where the rev counter feed is, not as simple as I'm used to, a green wire by itself or similar.
well assuming the rev counter works of the coil as it should
and the coil has been replaced, surely it's a power to the coil issue
check the gearbox earth and battery earth, maybe run a new earth to coil
and then check the positive for the coil, and again my run a permanlt live to the coil as a test?
I sorted out gearbox earth, was loose...
Cleaned with new washers, tight now.
Same with inner wing earths.
So many wires around the coil, wasn't sure what to do.
So you reckon power feed to coil, check this wire - any idea on colour?
Also run perm live from battery to this and give it a good run, see if it plays up.
Just need to find out what colour wire does what, and should be ok.
You any idea on colours?
Cheers mate
Cheers mate
ok to find the (switched) live on the coil, pull off one of the red wires, and put a multimetre on it, then turn the ignition on, if you get 12 volts thats the feed in, if it dont, it's the other red wired , once found temp replace this with a perm live
Red wires, who'd have thought
So if perm live solves it, how do I go about sorting it for good?
Not the best with electrics as you can tell
well, that live is Switched, as in is live when the ignition is on,
i guess it comes from tyhe fuse box, sp you could trace it back to there and renew the wire just as it comes off the fuse box.
or attach it to one of the wires off the ignition (but dont cut the ignition wires to add) just peel back the insulation and solder on it
No red wires, couple grey, blue, green and orange iirc.
One of greys had 12v, cut that and wired straight to battery, didn't make any difference.
Tried tracing wiring back...
Couldn't get it to start after a while, battery got tired but jumped it off my car with no luck.
Coil gets seriously hot, plastic bubbled at one point, ignition had been on for a while, but not hours.
Wondering if heat is doing it, but the rev counters a funny one.
When it won't start sometimes jumps once, others nothing, others climbs and climbs all time you're cranking.
Had a gutful of it now
IAN - Everything is stock mate
Connector has 4 sections, one of which fed 12v+ when ignition on, this I wired to battery.
Even wired normally coil gets bastard hot.
When it did run, would be idling fine, then just cut out and not restart.
Pissed me off, wasted a day off on the shit
ok one of the 12v will be from the coil, the other goes someone else (relay or somewhere,
so if you unplug one, and test the wire, it will switch on and off with the key
the other gets the live from the one from the key, if that makes sense
but you defo need a new coil
what year is your car??
i might have a spare one (but not sure)
It's NOT my car
One of wires read 5v or so, one 12v+, other 2 read 0.
Could this be a problem, the 5v one?
It's a G plate with TU3 engine I think he said.
Plastic case of coil bubbled for a second where metal got so hot, did run after this once cooled down, not for long.
I call it coil, it's this style as opposed to cylinder old type:
http://www.the-ecu-doctor.co.uk/Rena...0Amplifier.jpg
Matey has just said it started and ran fine just now, as it had cooled down.
Coil still had some warmth.
I don't know how hot they should get, or why this one is getting as hot as it is - seems to be root of all the troubles.
Any ideas mate?
Edit/ Fuck, I replied to this, where'd that go
Had a couple cars with misfires that have been the amp, but dropped a pot on 4 pot, and 2 on 6 pots.
Never heard of them affected by heat, but that isn't conclusive.
Just they're not cheap, have to hunt the scrappies.
The coil is nearly new, problem remained when renewed
Wondering if it's 100% correct one.
Any ideas mate?
Well he went on that forum, found exact same issues down to ignition amplifier - as I said only thing that hasn't been changed.
So far so good, cheers for link Spiky
big_Rad
15-09-2017 09:36 AM
James Porter
28-10-2015 12:17 PM
borboyous
22-08-2015 11:17 AM
Zoggon
10-08-2015 10:39 AM
