T25's How much boost can they run safely ?
Old 18-01-2008, 08:23 PM
neilm
neilm's Avatar
Default T25's How much boost can they run safely ?
My T34 is in need of a refurb and its got me thinking about doing something different.
I went out in Daryl Fletchers MkI Escort Camper Van a while back that Karl had mapped with a T3 on it and it went like a missile, much nicer than my laggy old T34 and it got me thinking about smaller turbos.
Plus I'm pumping so much cash into the Anglia stuff we are doing I aint got loads to spend on my cossie so I thought about a T25 and the Rouse type cars as they make bags and bags of torque and almost zero lag.
SO....
Whats the most boost they can run safely ?
Could I use one with my existing Green Injectors & 3 bar ?
Will my exhaust bolt up to it without any mods ?
Will my 500 Intercooler be ok with it ?
Old 19-01-2008, 03:44 AM
ryan_belfast
ryan_belfast's Avatar
I ran 1.3 bar through mine.
Old 22-01-2008, 12:20 AM
neilm
neilm's Avatar
You just gotta love this forum... A post about shaving your nads gets hundreds of views and plenty replies from boys with bald sacks...
But I ask a 'technical' question and nuttin......
Surely someone with a small turbo escort must know how much boost they run with their Stage I conversion.
Or someone with a Rouse can give a bit more info on the conversion
Old 22-01-2008, 12:40 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
What T25 is it?
There are many turbos that get referred to that way.
Its NOT boost that its going to be limited by though, it will survive a couple of bar probably, its the FLOW that is the issue.
Cossie will have it dropping off the right of the compressor map even at relatively mild boost.
Old 22-01-2008, 12:41 AM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Cant find what boost he run though...
https://passionford.com/forum/viewto...883&highlight=
Rebuilt Bluesprint Low comp engine
Long Studded
Sleeved block
Dished Pistons
BD10 Cams
T25 Hybrid Turbo 360 degree bearing
-31
Polished Ported head
Bailey Breather System
Green Injectors
3 Bar
MSD chip
Pro alloy RS500 cooler
Mongoose Exhaust
Ram air filter
Chip
Chip's Avatar
PS
Intercooler, yes it will be fine.
Green injectors and 3 bar will be fine, you will of course though need a new chip to run it properly.
You might need a flange adaptor if its a T2 flange like a lot of jap stuff uses.
Old 22-01-2008, 12:43 AM
Munch
Mr. Sparkle!
Munch's Avatar
i know what you mean mate, sadly i dont know i dont know anyone running a T25 lol
how much boost you thinknig of running, im sure there was one or two in Retro Ford a while back, Anglia thrash i think it was, mind you you dont need alot of power in a car like that, a stage 1 is more than enough imo
Old 22-01-2008, 01:04 AM
Robski
Robski's Avatar
do you mean the T28 turbo from the small turbo esc cos?.....i run around18-19psi on mine without any probs.....i hear a few on hear a few on here run even higher.....as regards to coolers and injectors,i would PM Stu for some advice
Old 22-01-2008, 08:22 AM
Twellsie
Twellsie's Avatar
is there any point going smaller than a T3, i run a T3 on mine and there really is next to no lag and mine peaks 2.1 and holds 1.9 bar (i think)
Old 22-01-2008, 08:26 AM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Rouse and Escos EEC didnt run the same turbo Neil so your question isnt ideal for a simple question, however, both are good for 20held reliably IMO.
You would need to get your ecu mapped to suit.
Old 22-01-2008, 08:29 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
neilm
How much boost do you run through your t34?
Old 23-01-2008, 11:02 AM
neilm
neilm's Avatar
Originally Posted by CossieRich
neilm
I currently run 24 psi.
Old 23-01-2008, 11:03 AM
neilm
neilm's Avatar
Ok... Its at Small Turbo Escort Cosworth Turbo I've been offered.
20psi sounds ace...
Can you do me an off the shelf chip for this Stu ?
Or do I need to come to blackpool... ?
Old 23-01-2008, 11:05 AM
neilm
neilm's Avatar
I know... my Anglia was the quickest normally aspirated car on the day !
I also know the chap who was quickest overall as he is the only person I've ever spoken to about Cossie'ing an Anglia who took my advice and went small turbo...
0-60 in 5 seconds dead is not to be sniffed at, especially as its on an auto box
Old 23-01-2008, 11:11 AM
neilm
neilm's Avatar
Originally Posted by Chip-3Door
What T25 is it?
Sorry Chip.. should have said, its a Small Turbo Escort Cosworth Turbo,
Old 23-01-2008, 11:12 AM
Off the shelf no problem if you have someone check the AFR before you give it death to the limiter in top gear pal.
Old 23-01-2008, 11:16 AM
Chip
Chip's Avatar
Ive got a wideband you can borrow to do that with if you havent got one Neil.
Old 23-01-2008, 12:01 PM
foreigneRS
Testing the future
foreigneRS's Avatar
would be lovely on a turbo like that with a good map i reckon
a live mapped t34 with .63 exhaust housing is not all that laggy or unresponsive though - just too much power to realistically use in such a narrow and light car, so i think you are going about it the right way
Old 23-01-2008, 12:20 PM
neilm
neilm's Avatar
I'm not that kinda driver Stu.....
Old 23-01-2008, 02:25 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
you will need to run a 360 thrust bearing on a t28 for 20 psi
Old 23-01-2008, 10:10 PM
neilm
neilm's Avatar
Bugger... this is a standard turbo of a Small Turbo Escort.
So what sort of boost can that run then Tony ?
Old 23-01-2008, 10:14 PM
neilm
neilm's Avatar
Errr sorry mate I think I havent explained myself properly.
Its for my 3 door.
All this talk of Anglias is because we have a project on to develop a kit to fit the 20v Toyota 4AGE engine into my Anglia van and thats where all my 'spare' money is going.
The T34 on my 3 door is in dire need of a re-build and I've been offered a very low mileage T28 cheap so I thought about using it as a stop gap.
But I always recommend anyone fitting a cossie motor into an Anglia to use the T25/T28 for the reasons you stated, narrow car with short wheel base.
JK12
33
26-04-2021 12:09 PM
dombanks
21-09-2015 08:38 PM
markk
09-09-2015 08:11 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
CrOwSoN15
14
03-09-2015 12:21 PM
Quick Reply: T25's How much boost can they run safely ?
