fitting a 4x4 fuel rail to a 3 door
Old 13-01-2008, 06:57 PM
Alps Pacino
Alps Pacino's Avatar
Default fitting a 4x4 fuel rail to a 3 door
I've got a swedish inlet for my 3 door which is welded for a 4x4 fuel rail and i was wondering apart from the fpr what else needs changing to mke it fit, ie do the pipes fit etc
Old 13-01-2008, 08:11 PM
Alps Pacino
anyone
Old 13-01-2008, 08:18 PM
col cos1
col cos1's Avatar
think youll need some sort of bracket welded on the side for throttle cable if your enlarging throttle aswell
Old 13-01-2008, 08:21 PM
dave cos4x4
dave cos4x4's Avatar
the bolt on brackets on the 2wd are different to the 4wd ones.
the reg bolts on too.
think thats it.
Old 13-01-2008, 08:25 PM
Alps Pacino
dave cos4x4
What bolt on brackets? you mean the mounts for the fuel rail? If so the swedish inlet i'm getting is welded for a 4x4 fuel rail and has the cable bracket with it, just wondering what else i might need. Doesnt the 4x4 fpr just bolt onto the end of the rail with no bracket to the inlet like the 2wd fpr
Old 13-01-2008, 08:27 PM
dave cos4x4
Alps Pacino
yes them brackets.
yes, 2 bolts to keep the fpr on.
should be ok with it then.
Old 13-01-2008, 08:29 PM
Alps Pacino
What about the fuel lines the fpr one should be the same as its just a pipe with jubalie but the other end is 2 different types completely iirc?
Old 13-01-2008, 09:45 PM
dave cos4x4
Alps Pacino
i will have to look at mine, i cannot remember.
Old 13-01-2008, 09:48 PM
lawnsy
lawnsy's Avatar
Some blue-tac
Stu @ M Developments
41
21-08-2015 06:47 AM
COSWORLD
14-08-2015 07:40 AM
Roosie
13-08-2015 09:38 AM
muffster
12-08-2015 08:14 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: fitting a 4x4 fuel rail to a 3 door
