rebuilding a turbo yourself
Old 09-01-2008, 11:28 PM
smitsturbo
smitsturbo's Avatar
Default rebuilding a turbo yourself
is it a major task & are there specialist tools needed?
Old 10-01-2008, 12:09 AM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
I want to know this
Old 10-01-2008, 01:00 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Do you have a 100,000 rpm balancing machine?
Old 10-01-2008, 01:21 AM
smitsturbo
smitsturbo's Avatar
not on me no
so it cant be done then, impossible without a machine?
Old 10-01-2008, 04:54 AM
NEIL A
NEIL A's Avatar
The actual rebuild shouldnt be hard or need any specialist tools , but as chip says its the balancing that will be the problem. It might not be that far out but with something spinning so fast its not worth it for all you will save.
Old 10-01-2008, 04:37 PM
Charlie Chalk
Unknown.
I'll pay someone then
Old 10-01-2008, 04:39 PM
rauri
up in smoke........
rauri's Avatar
Originally Posted by smitsturbo
not on me no
is kev bruce still at sulzer? if so get him to balance it
Old 10-01-2008, 04:40 PM
smitsturbo
smitsturbo's Avatar
not on me no
he is, i'll ask him
Old 10-01-2008, 04:48 PM
PAUL S
PAUL S's Avatar
If you are just changing the oil seals and no other moving components then there is nothing to re-balance
Just take it apart carefully, replace the ring seals and re assemble - easy to do.
I have rebuilt loads with simple tools and all worked fine for many miles afterwards with no more leaks, only awkward part is holding the turbine wheel in order to undo the compressor wheel nut as it has an unusual end on it
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
kevin36
02-09-2015 06:24 PM
rsturbo27
01-09-2015 09:54 PM
Quick Reply: rebuilding a turbo yourself
