Good jubilee clips for boost hoses on saph cossie,where from
Originally Posted by jb fletch
Andy, where can you get the Norma one's from ? ? ? Are they different looking to the normal jubliee clips ? ? ?
look simillar but far better quality
you don't have much fear of stripping them when tightening them
There may be a motor factors near you that stocks them, worth a phone call to find out:
Norma Products Limited (UK)
Arnhem Road
Newbury
Berkshire
RG14 5RU, UK
Telephone: (01635) 574000
Fax: (01635) 582867
Web: www.norma.co.uk
mikalor are pish use murray clamps proper wrc jobbies
http://www.owendevelopments.co.uk/pr...rray-clamp.asp
I had lots of boost leak problems with the mikalors but since fitting the above have had no probs
Mikalar and other clamps or the similar design are not any good for boost hoses, But good for Exhausts if St/St.
i tried many different designs on my cossie, as 50psi boost leak tests just seems to find leaks/faults in most.
The best i have found are Hi torque St/St J clips, but make sure the worm thread doesn't stick thro the clamp as this will damage the hose.
*** Sierra RS Custard ***
Murray clips get my vote too, absolutely awesome fasterners
Its what my mate Neil is using on his westifeld ive been helping him with the engine on.
They are as easy to use as a jubilee clip but with a much more even spread of pressure around the pipe.
Quite expensive, but given how few you need on a cossie, its not really an issue IMHO
On here to much!!
Does anyone know off the top of there head what size clamps are on the boost hoses on a small turbo escos? going to order some today but im not where the car is!
Could my car's hunting at idle be caused by my mikalor clamps leaking ????
I've also just had my turbo rebuilt and Vince did ask my if i had any hoses come off because the blades looked worn usually caused by overboost
Again could Mikalor clamps be to blame?
What D/V are you using though, as that could be leaking too of course.
Not if its running Map sensor.
could be if running small turbo AFM.
rsstav
Ford Focus RS Parts for Sale.
16-08-2015 08:38 AM
rsstav
11-08-2015 04:22 AM
CabrioTurbo
01-08-2015 11:04 AM
