dizzy timing t34 escos
yep everything is timed up and the rotor arm lines up with mark in dizzy . phase sensor gap is good . just didn't know if the ecu needed a little help
thanks tabetha i can always rely on you for info
aslong as its on its timing marks, your all good
one thing to check is the woodruff key in the crank isnt warn allowing your crank pulley to move!
if your not too sure where everything should be pointing
http://www.cannell.co.uk/Manuals.htm
theres a few manuals there you can use
So long as you have used the TDC mark and NOT the ignition mark to time belt up!!
I have seen these timed on the "V" groove, instead of the LUG, nearest the "V" groove which is the TDC mark.
wheelwizardrefurbs
23-09-2015 09:14 PM
yawiejon
15
09-08-2015 06:36 PM
