VIDEO OF MY NEW ENGINE RUNNING ON PAGE 2 :D
#81
Originally Posted by James-W
better handling, with all the weight of the turbo in the back?
Awesome work chipper, it will do the business
James
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
James
#86
1st to 200 without NOS
Originally Posted by Chip-3Door
martin. I've not tried it there before if it prooves a problem we'll just move it. it was spitting lots of flames out the wastegate hole when we ran it without the gate to test it though so it seems like the gasses will go that way
#89
huge charge cooler. 19 litre capacity of water. two cossie intercooler cores inside it. it mounts low down at the back.
garage19 is just finishing it off for me now
martin. will do. I think I may need a second or larger wastegate than the 38mm though
#93
Unknown.
#94
DEYTUKURJERBS
Originally Posted by Dan@FastFord
what power are you expecting from the engine chip?
iirc a 38mm w/g is good for 600bhp
much more and you need a 42mm one
basically the bigger the turbo and the lower the boost you wanna run, the bigger the gate needed so less gas goes thru the turbo.
#99
Originally Posted by AlexF
LOOKS GREAT!
But will a mini with red wing mirrors pass you at bedford??
Probably, at bedford I will be running on wastegate pressure only (if its even run in by then to go at all as still got a lot left to do) which is only 0.7 bar
#100
Originally Posted by Cosworth Bassie
Love it mate
What are the full engine specs?
Approx specs from off the top of my head;
VAUXSPORT STAGE 1 CONVERSION comprising of:
Engine Bottom End:
C20XE block
Line Bored
Sump surface machined flat
Head mating surface machined perfectly parrellel to bearing tunnel
Bores exactly perpendicular to bearing tunnel
Block stress releived by hand to remove casting marks and other stress raisers
ARP mains
ARP headstuds
ARP2000 rod bolts
Steel XEV crank
Arrow Conrods
Arias Pistons
Oil Squirters
Cylinder Head:
Coscast casting
Neil Roper Developments port bored inlets
Neil Roper Developments port bored exhausts
Neil Roper Developments hand finished inlets
Neil Roper Developments hand finished exhausts
Piper double valve springs
Solid lifters
+1mm 214n stainless exhaust valves
+1mm 214n wasted stem stainless inlet valves
Cometic 1.9mm gasket
Gearbox
Getrag F28
Quaiffe ATB diff
Twin plate paddle clutch
Lightweight flywheel
Inlet
SBD/Jenvey throttle body manifold
Jenvey throttle body spacers, 50mm
Custom made inlet adapter plate
19mm ally trumpets
RS200 inlet plenum
Vectra V6 64mm throttle body
2.5" ally inlet piping
Blue silicon hoses and joiners
Turbo
GT35R Garrett
Tial 38mm wastegate
Earls filter
Braided feed line with inline flow restrictor
Exhaust
Garage19 manifold to my specs
Garage19 produced exhaust to my specs
Garage19 wastegate pipework to my specs
Steel exhaust gasket
Ignition system:
NGK Iridium plugs
Nologoy hotwire leads
#101
Bit of a rubbish spec really Chip
also don't you mean XER steel crank
Did you run a ecotec crank pulley and the ecotec multi belt bottom pulley to get round the different bolt arrangement ?
#108
Looking good, I still remember when you took me out in the red LET nova when I had the datsun................in the WET
seems like a billion years ago now, nice to see things evolving
#109
Shame cause relatively speaking for a light fwd car of that power, that one was actually pretty good as it was on big shafts and a quaiffe diff.
#110
MAD Carbon Cossie
Getting there Chip, well done & still very impressed !
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
PMSL @ the "bollocks........... can't shut the boot" comment !
Chip if you need any help wit this give us a bell & i'll see ya @ the Surrey meet wit that thing !
jb
#112
Happily retired
Thanks JB, see you at the surrey meet then ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Blimey Chip you have finally done it, I wont be able to take the mick any more. Looks good & im sure it will perform just as well, see you & JB at the surrey meet, best remind me when it is.
Rod
#113
Im not sure myself when surrey meet is, it was meant to be yesterday based on the "first tuesday of the month" principle, but I assume its been moved as that was new years day of course.
Just need to get the engine run in and onto the autronic now
#114
![](https://i7.photobucket.com/albums/y251/chip-3door/4m2/nova-wired.jpg)
Looks like it will be fun when done
As you know, the problem with waste gate exit is to get it to flow well in both directions with out one impeding the other too much.
Toughest test will be when Chip is running 0.7bar to run in.
I have done a quick MS paint drawing to better show the actual angle/take off from above.
![](https://i33.photobucket.com/albums/d90/Garage19/WASTEGATANGLE.jpg)
#116
LOOKS GREAT!
My manifold flows very well towards the gate, and i struggled with a 38mm gate to hold 1.4 bar, it crept to around 1.6 at top rev's. (GT35, Strokered Evo)
Still though, only 1 way to find out, awesome car, what exhaust housing is on the turbo? 0.63?
Is the screamer going into the exhaust?
#117
TBH while im running it in, I can always just adjust the throttle position to limit flow on the way in as well.
Will still be nice to get it out on track for a bit of a "shakedown" even if the wastegate control struggles at the level of boost I want to be running that day.
#119
LOOKS GREAT!
What turbine housing were you running on the GT35? I know some of the GT/HKS hybrid evo turbos seem to run very tight exhaust housings eg Hks GT25/40.
I guess we will just suck it and see.
