issue fitting oil cooler sandwich plate
i've never fitted one of these so i assumed i removed the OE water/oil cooler (like on cossie's) and put new thermostat controlled sandwich plate and job done??
but i cant, if you look at the pic below
one is the OE bolt that holds the old cooler on, which has male fittings each end
yet the new one has male one end female the other,
it's as if i just attach the new sandwich plate to te OE one and just not use the water pipes
or do i have the wrong fitting???? or just being stupid
1st to 200 without NOS
Re: issue fitting oil cooler sandwich plate
the filter and housing.
Originally Posted by martin-reyland
Is it 4x4? If so bolt it back together and put the sandwich plate in between
it seems a bit stupid to leave the OE on inplace
and the oil cooler will be trying to cool it
though i can leave the OE in place and not plumb it in
Thats the reason I reckon if you ask whoever you had the kit off
but then on track the water will be heating the oil
i was talking about the oil
but surely having 110degrees constanly heating water, is non effiecent??
surely it would be better to not HEAT the water with the oil
rememeber this is a TRACK car not a road car
Sorry it looked like a 4x4 cosworth set up!! You need to fit a threaded insert into the block(I can supply if needed), ditch the old oil cooler and fit the sandwich plate between the block and filter. The cooling pipes on the old oil cooler just need joining together.
i will see what my supplier says, if he cant get it i will get one off you, after all i did pay for fitting kit
found the answer, you correct martin too, (not that i ever doubt'd you )
as i ask'd the same question on the 205 forum
Easy, As all the Iron blocks with the heat exchanger fitted use the fitting as in your picture and is one complete item, On the alloy blocks they still had the thread insert in the block, You can buy these from Pug for a couple of quid, If you need the part number drop me a PM (which i've asked )
ekjim
17-08-2015 08:57 PM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
