how do ISCVs work? as i missing something?
Old Oct 11, 2004 | 01:56 PM
Jim Galbally's Avatar
Jim Galbally
Default how do ISCVs work? as i missing something?
ok the way i thought an ISCV wored is that its a bypass for the throttle butterfly... ie air enters ISCV from before butterfly and is re-introduces after the butterfly...
and ofcourse the ISCV opens/closes bla blah to bypass more/less air hence increasing/decreasing RPM...
so...
how the feck does a remote ISCV work then? ive seen ISCVs just bolted onto hoses before the throttle with nothing going to the post-throttle side of the intake...
how on earth do these work?!?!
im sur theres something obvious im missing, but i cant understand how on earth they work!
Old Oct 11, 2004 | 01:58 PM
Jon ERST S2's Avatar
Jon ERST S2
in the same way! one pipe in one pipe out.
I got a pic of mine somewhere..
Old Oct 11, 2004 | 02:00 PM
Jim Galbally
jon, but what if there is nothing leading to after the throttle?!
JohnnyB's Avatar
JohnnyB
no Jim,
The ISCV just monitors the air and tells the ECU whats going on the the ECU adjust the engine
Old Oct 11, 2004 | 02:02 PM
Jon ERST S2
Old Oct 11, 2004 | 02:03 PM
Jim Galbally
so surely that'd just be called an "air measuring sensor" not an "idle speed control valve"
infact wait a sec, isn't that what an airflow meter's for
and how does the ECU adjust the idle speed with no air bypass for the throttlebody, it cant open physically open the throttle, so surely all it can do is adjust the timing and fueling to affect RPM
Old Oct 11, 2004 | 02:06 PM
JohnnyB's Avatar
JohnnyB
it just add's or leans the fuel
Old Oct 11, 2004 | 02:07 PM
JohnnyB's Avatar
JohnnyB
O jim The airflow meter is not good enough at low engine speeds
Old Oct 11, 2004 | 02:09 PM
Jim Galbally
but then surely it wouldnt be an ISCV right? just a little diddy airflow sensor?
Stavros's Avatar
Stavros
DEYTUKURJERBS
All cars have ISCVs that bypass the throttle in some way, dont they? Post a pic of what on earth you on about Jimbo, as all ISCVs, even remote ones, have a pipe going to them from before the throttle, and one going to after the throttle...
Old Oct 11, 2004 | 02:11 PM
Jim Galbally
i think the pic that got me thinking was kenny @ msd's car
but it wasnt clear in that pic... just reminded me about it, as ive seen a few before of just a normal lookin ISCV bunged in a hose somewhere
Old Oct 11, 2004 | 02:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Yea, lots of remote ones, but always 2 hoses, one leading somewhere before the throttle, and one leading to somewhere after, as like you know, they just allowing air into the engine when the throttle shut.
Infact on a MAP based managment you could have the 1 pipe to atmo and one to after the throttle as far as i can think....
JohnnyB's Avatar
JohnnyB
Steve just stick a volt meter on on and all it does is read the air flow.
The ECU has no control over it. The piston inside may automatily do somthing though
Old Oct 11, 2004 | 02:37 PM
Jim Galbally
i beg to differ
Old Oct 11, 2004 | 02:49 PM
GARETH T's Avatar
GARETH T
remember it doesnt have to have a two pipes, aslong as it can increase the air flow into anywhere after the throttle body your ok!
Old Oct 11, 2004 | 02:51 PM
Jim Galbally
gareth, how can it increase airflow without an input for this extra air?
JohnnyB's Avatar
JohnnyB
I could be wrong jimbob, But I remmber being corrected once.
Old Oct 11, 2004 | 02:52 PM
Jim Galbally
well johnny, the valv inside dont open itself by magic, it opens when its TOLD to do so
GARETH T's Avatar
GARETH T
i only said two pipes,,, it could have an air filter on it
Old Oct 11, 2004 | 02:53 PM
Jim Galbally
ah i see what you mean there
JohnnyB's Avatar
JohnnyB
The piston will move due to sucksion its very light
Old Oct 11, 2004 | 02:57 PM
Jim Galbally
i see your point there...
AlexF's Avatar
AlexF
Johnny you are utterly wrong!
The ISCV valve moves under direct control of the ECU as Jim describes!
Just coz its not connected doesnt mean the engine wont idle thou...
Alex
Old Oct 11, 2004 | 02:58 PM
JohnnyB's Avatar
JohnnyB
I am probly talking shit ISCV the v bit is valve, But I remmeber somone conviceing otherwise
Old Oct 11, 2004 | 03:00 PM
JohnnyB's Avatar
JohnnyB
A engine will idle with out ISCV your right.
foreigneRS's Avatar
foreigneRS
Testing the future
sorry johnny b, but you're wrong as far as normal ford ISCV's are concerned.they do as jim and steve are saying.
i can't see that somebody would build in a remote oe and then not have it go anywhere, that's just pointless. maybe it was one for anti lag that wasn't finished or had been partially removed?
Old Oct 11, 2004 | 03:01 PM
AlexF's Avatar
AlexF
I know, I worked on them at ford
Old Oct 11, 2004 | 03:02 PM
JohnnyB's Avatar
JohnnyB
Fook know's I think it was the fookin book of sum description and or mag were I read it.
I bet it was fast ford or the somthing
Old Oct 11, 2004 | 03:03 PM
JohnnyB's Avatar
JohnnyB
I know guy's I know I know I am wrong the way jim doescribed it first was the way I though, but as I say I read somthing someware and it changed my mind
JoeyBoyden
Jan 4, 2024 02:36 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
muffster
13
Sep 3, 2015 09:40 PM
borboyous
Aug 22, 2015 11:17 AM
