will this sump return be efficient?
Old Dec 13, 2007 | 04:01 PM
paceo's Avatar
paceo
Default will this sump return be efficient?
had my return plumbed into my sump and it sits way above oil level, do you think it will be ok to use as its more of a right angle return. its twice as thick as the standard fiesta t2 return at 20mm thick.
Old Dec 13, 2007 | 04:30 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If its above the oil level, no problem
Old Dec 13, 2007 | 04:37 PM
Luca's Avatar
Luca
Lukesville
That looks like it will drain okay, however is that far enough away from the alternator....... from the angle your photo is it looks like where the alternator would hang
paceo's Avatar
paceo
its about 1.5 to 2 inches above oil level, i tried it with some water - 3.5 litres just wanted more f a curve like my old return-
Old Dec 13, 2007 | 04:38 PM
Chip's Avatar
Chip
curve is better on paper, but TBH it wont matter in reality, the volume flowing through it is very small anyway
Old Dec 13, 2007 | 04:44 PM
paceo's Avatar
paceo
hi mate, i have relocated higher up and to the left away from it sitting directly behine the oil pickup bracket.
here is where it sits now (red dot)
Old Dec 13, 2007 | 07:26 PM
Luca's Avatar
Luca
Lukesville
Puuuurfec
Old Dec 13, 2007 | 07:43 PM
paceo's Avatar
paceo
a few people disagree with a 90 degree angle on fiesta turbo.com cant fault the welding, its top class! id prefer the t3 return pipe though!
Old Dec 13, 2007 | 07:55 PM
Luca's Avatar
Luca
Lukesville
Mate, take everything you here on there and double check else where, somepeople help others just like to stir.
There wont be any issues with that at all... Just make sure to wrap it or the downpipe as the heat from the exhaust may kill the silicone as could the oil if its not the lined silicone
Old Dec 13, 2007 | 07:59 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Luke's raised the point i was just thinking - personally i'd go for braided hose
Old Dec 13, 2007 | 08:00 PM
paceo's Avatar
paceo
dont worry its samco flurolined for oil and is sufficient for up to 930 degrees, Ł60 a meter tho
Old Dec 14, 2007 | 09:15 AM
paceo's Avatar
paceo
will give it a go in the cold today, sump was also damaged on the carrier so i have to bend the lip back, touch wood it wont leak.
Old Dec 14, 2007 | 10:08 AM
Luca's Avatar
Luca
Lukesville
im glad my cvh sump fitting days are over- worst thing ever to install
best of luck though mate
Old Dec 14, 2007 | 11:22 AM
paceo's Avatar
paceo
piece of piss, look at my sticky guide in the fiesta turbo section.
Old Dec 14, 2007 | 11:28 AM
Luca's Avatar
Luca
Lukesville
I hung my silicone gun box of bolts and patience when i sold the cvh mate...
zetec now
155lee
Oct 27, 2015 04:55 AM
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
little bram
Sep 21, 2015 02:50 PM
BRAM
Sep 8, 2015 07:11 AM
