geometry experts.....discuss
i need to know how crucial is allingment of the rear wheels to the front wheels
i have had a completely adjustable suspension set up made for my xr2 front and rear, it was all set up and the rear wheels were alligned true to the fronts by moving the rear axle left or right to suit but now its alligned it is causing clearace issues in the inner/outer arches, i have loads of room on 1 side on the inner arch and none on the outer and visa versa (sp)
so how crucial/beneficial is this? as it would solve a lot of issues for me to align the beam by giving an even 50-50 clearance against each wheel arch rather than being true to the front wheels.
opinions please
opinions please
well the fronts cant be moved left to right as the driveshafts determine how far in/out the wheel sits, only the camber/castor/toe can be changed so that makes no difference
i no the shells are not true by a long way to start
the question is......will i benefit/notice the advantage (if any) of the rear wheels being aligned with the fronts rather than aligning the axle to sit the rear wheels nicely in the arches?
Its absolutely crucial that the front and back alignment is running true.....first thing to check is the corner to corner measurement, this will quickly tell you if the car is out of alignment.
Get the car on a nice level surface, with the front wheels straight, transpose the centre line of the tyre/wheel down onto the ground, push the car back and then measure the marks diagnally corner to corner, a couple of mm wont matter but it should if you do it acurately give you an idea of how far out the car is.....if its out after that i'll tell the best way to check and adjust alignment....
A car can measure fine alignment wise, but still be crabbing..
HTH
Ian
HTH
Ian
the suspension alligned when i had all the components made for the car and fitted
i think il get it fully checked over again, as bye eye it looks like 1 front wheel has more camber than the other so maybe the whole thing was not done accurately
it's all about thrust angles and the like, plus you have things like the ackerman steering principle that may or may not affect the amount of turn you have
on a short wheelbase vehicle it tends to be much more crucial to get this right
you've also got to make sure that the wheels follow themselves else the car tends to have crabbing issues
so yes, i'd say the rears are just as important as the fronts
opinions please
opinions please
We currently use the Hunter DSP 600 4 wheel aligner with the extended lift.
http://www.4wheelalignment.co.uk/
thats the plan then,
im going to get the ride height how i want it at the front and back (possably turret the rear for coilovers) then i get it all re checked andset up again
cheers
cheers
DaveEscos
Oct 29, 2005 12:42 AM
