Supension Geometry Q's
Few questions for you all (Sapphire Cosworth 4x4):
1) Does anyone know the Ford specifications for rear suspension geometry - Camber and Toe please (Cant find it in my manuals)?
2) Does anyone have any preferences regarding geometry settings that differ from the usual specs u get at your typical tracking place. and what are they?
3) Long shot - does anyone know what geometry the rally cars would have run for tarmac stages?
My car has the usual koni's, -25mm springs, poly bushes etc and it tramlines and is generally fidgety on the road
Any answers mucho apprecio
Neil
Neil
The only problem you have Neil, is that with your current setup you can only adjust the toe angle (tracking)
The tramlining can be caused by the car running to much neg camber at the front due to the lowering springs. We sell just as many sets of adjustable TCA's to correct this and give people less camber as we do for the track day boys that want to run more.
It is worth getting your car 4 wheel aligned to see if anything is bent, also if your tracking is wrong this can cause the car to be fidgety, especially if the front wheels are toeing out at all.
HTH
Sean..
HTH
Sean..
Cheers Sean
Currently (well, 2000 miles ago),
Front:
Toe, 0deg5min (left), -0deg5min (right)
Camber, -1deg48min (left), -1deg49min (right)
Rear:
Toe, -0deg9min (left), 0deg4min (right)
Camber, -1deg40min (left) -1deg43min (right)
Well within ford specs! (fronts, anyway)
Guess some of it is personal preference, but I preffered it more on the chassis dynamics standard height springs I used to have - everyone says 'oh they handle better lowered', but if anything - I have found the opposite
Neil.
Front:
Rear:
Neil.
OK in my opinion (as you say a lot of geometry stuff is personal preference)
The tramlining is due to too much camber on the front and the fact that your wheels are running parallel.
The level of neg camber you are running both front and rear is gonna chew the inside edges of your tyres matey.
Sean..
Sean..
Thanks for the advice Shaun - something to go on at least
Will get the Gaybird decamber plates on, and get some toe in put on for now, and look into getting some adjustable TCA's in the next couple of weeks
Neil.
Neil.
Originally Posted by dingy
Mine runs 3 degrees cambre, i just let go of steering wheel and let the road take you
Ever thought of less camber and a stiffer ARB matey??? Would make it stronger under braking and better through fast corners surely?? Do they do an adjustable ARB setup for the front end of a Mk2??
We fitted the gaybird plates to brad/bondy's 3 door...
Actually did fuck all.....so we took them off, car was same, refitted, was same.....big waste of time and a tenner LOL.....emailed mike bout this with no response LOL....
so we have some here.
Sean its a gartrac Tarmac ARB running a tension strutt tarmac setup on tarmac arms and front strutts.....its not as bad as i make it there, handles well on road, can't say for track as it aint been on yet.
Cool man. Book me a place in your passanger seat at National day matey!!
I will have my tyre temp pyrometer with me at Donno. You can take and store 12 temps at once with it (inside edge, outside edge and the centre for all 4 wheels). Tyre temps are the ONLY way to get your cambers right, i'd like to measure yours actually to see what its doing???? Plus will tell you if you are using the correct pressures.
Sean..
Sean..
Neil,
I would agree with Sean on the front camber.
Personally, I've always found std ride height best on the 4x4's I've driven.
However, mine used to tramline like a fucker, and the rear end would wander all over the shop. Get a particularly nasty lorry tyre track in the road, and the back would feel like it was about to let go!
Get on the case with the TCAs for a start and go from there..............
Caraholic
Funny how everyone else has / can notice the difference apart from you . Perhaps the Dingly ass-dyno needs recalibration?
Neil - told you so .
I emailed and text ya LOL
They don't stop the suspension moving up......ass dyno don't do wheel movement my eyes do
Brad and bondy both said.......
"well two bits of tin for the skip then"
Why would they not be working?
why would it look the same?
why would 3 people driving it notice no difference ?
It aint my car so i don't care but it has made NO difference, regardless of other peoples use, this is a track car and has been tested. Has anyone else tested it or just had thoughts in their heads it was better when it actually aint.
PMSL - Stops wheels lifting in arch's
IF you can't tell by drivin it, then whats the point ?
Regardless of measurements, if it feels same its not working is it.
I give in, the allmighty mike R is correct.
It works mint, i got my blinkers on look
Originally Posted by Neil S
Cheers Sean
Front:
Rear:
Front:
Rear:
Originally Posted by Rainbird
-----Original Message-----
Sent: 10 August 2004 16:53
To: Neil Stockton
Subject: Re: Tappets
Front: 2° negative camber, 0" 20' toe in.
Rear: 1.5° negative camber and 0' 0" toe.
Neil.
PS
I will be
Next week in fact
Neil.
Ah, good old blinkers - it looks like it can't have any effect, so ipso facto .
You should have measured the geometry before and after .
Next week in fact
Neil.
DaveEscos
29-10-2005 12:42 AM
