Skyline gearboxes
Skyline gearboxes
Does any1 know anything about skyline gearboxes?
Like what different types there r?
Which r the strongest?
Gear ratios?
Were 2 get hold of them?
and any thing else!
Whats involved in fitting them into cossies?
Am looking at building my track toy as bulit proof as possible and a skyline box seems the only budget way of doing this and keeping the 4wd!
Only rearly intrested in the gtr 4x4 boxes but other people might want 2 know about the 2wd ones!
Gear ratios?
and any thing else!
Italian convert
Cheapest option (relatively) would be a 5 speed box and transfer from a 32GTS4 which also has ratios more suited to a Cosworth running std ratio diffs or alternatively a late model 32GTR or 33GTR 5 speed and transfer. You will also need the pumps and plumbing that go with the transfer.
The tunnel will need alterations to allow fitment so its a very involved job.
Er budget !!!!!! lol
I did look at the reyland conversion but 8 grand if i rember right!
And no disrecpect 2 martin as i know that isnt excatly a standard skyline box he fits! And having seen his workmanship close up every penny would be worth it!
Found anotherplace that would fit a standard skylinebox for 1.5k with me suppling the box!
But since i am an engineer and a fairly good welder i cant see any reason 2 pay some1 2 do it for me!
Plus it would be so much more rewording 2 build the car completely myself! Thats if i all holds 2gether afterwards!
The way i c it there is nothing majorly differcult about it!
1) Adapt floor for box 2 fit
2) Make bellhousing 2 mount skyline box 2 yb!
3) Get a custom prop made (skyline one shortend, with fitterment for ford diff!)
4) Hydrolic clutch kit
5) Recut hole for gearstick (been told they dont come out 2 far froom standard?)
6) Sort out front prop (no idears on this bit yet!)
7) sort out anywirring!
What else am i missing!
1st to 200 without NOS
There is a bit more to it than most folk think though...
Italian convert
BUT.......Then you need to sort out the hydrualics/electronics that control the centre clutch.
FYI, The R34GTR has a 6 speed Getrag gearbox but the earlier 5 speed would be a better option as parts for the Getrag are hard to come by and very expensive.
Martins OSG sequential conversion is a bargain for the quality of his install
o Martin im sure there is otherwise every tom dick and harry would be doing it and u wouldnt be charging what u do for it!
But like i said id like 2 give it a bash myself first and then if i fail u will be getting a phone call 2 rescue me! lol
MD Cos I know i just got a friend of mine who works at nissan 2 print me of everything he can get regarding the centre diff pump and all its controls! so hopfully this will shed some light!
However he rearly couldnt find out much in the way of the differences in the different models boxes! This is were im being held up! Dont want 2 go buy a r32gtr box only 2 find out that the 34 boxes r stronger or what ever!
DEYTUKURJERBS
R32+33 boxes are the same, as are R32GTS4 boxes, only the clutch operation is slightly different on later models, but thats seperate to the box itself really, and earlier ones are MUCH better as to fit most uprated clutches you need to change to the earlier push clutches.
5speeds are as strong or stronger than 6speeds, and a LOT cheaper.
I got a spare R32GTR gearbox if you want. Push clutch model. Front diff etc too, but doubt you need that.
Good luck if you go for it
i did look into this aswell
just couldnt find anyone to do the bell housing for me or tell me about the clutch
it would be a cheaper option for me aswell tbh, a si can get askyline box fairly easily and no doubt all the pumps etc
a good std skyline box will take around 500 bhp ive been told aswell
props wouldnt be an issue to get made either i wouldnt of thought
but it is a lot of work to get done
but thinking of it your looking at around 1k-1.5k for the box and everything with it
custom bell housing
custom props
clucth
hydraulic conversion
and poss more
it would proberbly just work out either alittle cheaper or a little dearer than a quaife box or similar, so is it worth the hassle when you could save the money and have a strong cossie box fitted
custom bell housing
custom props
clucth
and poss more
escort mk4 cossy 4x4
DEYTUKURJERBS
Originally Posted by kjc300
Would the plates in the centre diff wear out if you ran it 4wd all the time?
aside from 32s (maybe not even the V-Spec 32s, i forget), ALL skylines run permanent 4wd, only a very little bit maybe, but some power to both wheels all the time. done for stability at high speed in a straight line, etc etc.
so they apart from 32s, it is running them totally RWD (if you was wheelspinning and doing burnouts that is) that would (albeit slowly) wear the centre diff out.
but on the cossie setups that ive seen, the 4wd hasnt been active (ie it doesnt change torque split on its own, you do it), so it should be able to be set from nothing to full, so no wear on centre diff regardless.
Engine Machinist
custom bell housing
custom props
clucth
and poss more
custom bell housing
custom props
clucth
and poss more
well worth the hassle imo, the mt75 is known for 2 problems, firstly having a weak third, secondly having shite syncros. a quaife box is no good for 500hp, fixit/mullit maybe, but if you're wanting to give it hard launches the box will be nearer Ł5k as i understand
has anyone thought about putting the attessa system in their car?
MD Cos
really ive always though the mullet box was around the same price as quaife, but being honest havnt lookd into it much
may have to look into the skyline box a bit more then
but its just the clucth and bell housing i need lol
clucth id imagine would just be one that could be used with a cossie clutch cover as long as its the same diameter and thickness of a cossie one
but could be way off the mark here again
we put a early jag box on a 1960s 327 chevy but that was very simple just adapter plate behind bellhousing and a bush for the back of the crank to reduce down for shaft. and used jag clutch plate
Lloyd,
How do you run the car mostly, 2wd? Would the plates in the centre diff wear out if you ran it 4wd all the time?
renton 'sort the wiring' might be a slight under estimate of what's involved
LOL yer a tad optimistic i know!
How does martin get over the bellhousing problem? Cut of the skyline 1 and weld or bolt a new custom made one on! If so does he sell them sepratly? Never liked the idear of spaces!
Thanks for the info guys! and i know every one sujests the 5 speed but if im going 2 go 2 all this effort it would have 2 be the 6speed id use! just got 2 find one now! Proberly be easier buying a complete crashed r34 then at least id know id got everything! then brake the rest 2 recoup some funds!
Engine Machinist
i've seen r32 + 33 boxes on ebay for Ł275, up to Ł800ish and an r34 box for Ł3k
stavros tells me that the r32 uses a pump run off the engine to control the diff, but thinks an r33 uses an electric one. (iirc, was a late night last night and i havent looked through my pm's again, so apologies if i misunderstood )
cossie clutch and skyline clutch plates are same diameter, so was going to get the skyline plate and see if it'll fit with the cossie cover. splines are slightly different.
Engine Machinist
care to divulge anything about it martin?
Engine Machinist
another thing though, will you sell the centre diff controller seperately?
chowfornow
14
05-01-2019 09:01 PM
