astras
astras
m8 of mine going to look at a couple of astras tonight one is a new shape on an s plate 111000 on the clock
and the other is a older R reg 108000 ON THE CLOCK
what are these vaxhaull engines any vaxhaull gurus on here who can give me some advice on what to look for apart from the normal rust thanks in advance
thats not that many miles really,fairly average.ten years old nearly so not even 12000 a year!and as for the engines,erm...for a start theres no indication of petrol or diesel,or engine size or ANYTHING!more info might help a little
The 8 valve engines are better with miles on than the Ecotecs in my experience [for the petrol]. The diesel engines ae great, but Can suffer with head gasket failure.
The breathers in the rocker on the 8 valvers get blocked and gunk up, so if you see what looks like the gunk [like if the head gasket is going] under the oil filler cap, check the water as well [make sure there's no oil in there] as they normally just need the rocker taking off and to be cleaned through.
Ecotec?
Every
Component
On
This
Engine's
Crap
Bit unfair at those sorts of mileages though as they'll either be TOTALLY fucked, o have had all the problems ironed out.
Guarantee if you took a dozen of each, there'd be less rust on S plate Astras than equivalent Escort!
They're just old cars now though mate to be honest, so check everything you would on any other car
Ecotec?
Every
Component
On
This
Engine's
Crap
ecotecs have a bad name for no aparent reason
im an ex vauxhall tech and i find them to be very reliable
8v's on any engines are known to be more bullit proof, but 16v's are more economic and faster
any astra on 100K should be ok as long as it has a decent service history,
Thrush
13
27-11-2004 07:11 PM
