Cometic Exhaust Manifold Gasket - Updated
Originally Posted by Christian and Beccy
This is the exhaust manifold I am talking about, not the head gasket.
I need an exhaust manifold gasket that allows for bigger exhaust port sizes, not sure if the Cometic does, or can be ported. The standard gasket can't.![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
yeah, and at a guess the CVH exhaust mani gasket will be the same material as a YB ex mani gasket, which has been fine on my cossie.
but as for port sizing, i can't help.
but i used to make Ex mani gaskets for cvh's years ago, using marine grade exhaust gasket material.
The guy that made the flange has the DXF file for it and said that he can probably cut the gasket too. I would probably try and buy enough material so that I can get 4 or 5 gaskets. Should be enough to last forever!
It's just a case of finding the best type of gasket materal to start with.
caprixpack
25-09-2015 07:53 PM
