anyone ever made a custom bellhousing adapter??
anyone had 1 made? or make your self?
transverse mounted engine,
ANY ONE NO WHO CAN MAKE ME A CUSTOM BELL HOUSING ADAPTER?
just finding my feet
Originally Posted by Shings
TOny nutsrus did one for the RS1600i rally car.
If its just a adaptor plate then its not really much of a job for any machinist.
If its a fully custom bellhousing then I expect it will be a little bit more tricky and expensive.
My mates cossy transit ran a adaptor plate on the block to allow a transit gearbox to fit
Re: anyone ever made a custom bellhousing adapter??
Mark
The homemade 3" offset lightweight flywheel took a week to make in the lathe though
The car has killed many a scooby scalp out on the stages Al, so that would have been a backward step
And its still running, dosnt chew gearboxes or blow engines to bits for fun
head gasket issues perhaps in the early days
tone you KNOW i LOVE your car,,,,,, the work done to it is IMENCE
but cant help thinking if you stated with a better base car,,,, what would that be like
I used P20 tool steel
http://www.crucibleservice.com/datas...TOKEN=23312534
We use it a lot at work but it is a PITA to machine and took me plenty of hours to make
Engine to gearbox adaptor is the easy bit "IF" you have accurate dimensions to work from
Mark
The homemade 3" offset lightweight flywheel took 8 months to make in the lathe though
wowk
30-03-2021 07:49 PM
