why does my car keep getting stuck in 5th gear?
its a s2 turbo got a new clutch fitted and box recently rebuilt!
the old box did it aswell so changed the box all togeather does it every now and again!
any ideas cheeRS
any ideas cheeRS
linkage is new mate!!
it gets stuck in gear u can put clutch in and the gear leaver wont move!
turn the car off and it comes out after a while
could it be the clutch quadrant?
Give ya £800 fot it r kid, old man would be happy for it to be gone from drive....
On a serious note is it the clutch itself?, or release bearing??
Originally Posted by Ollie MK5 Turbo
BC gearbox’s do that sometimes
if you run in 5th for a long time.
Just pull it harder next time
any ideas please
Originally Posted by Jamz
hammer ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
For two boxes to be doing the same the fault must be either the clutch (dragging/not fully disengaging) or the linkage incorrectly adjusted.
Where is the bite point on the clutch pedal? Can you engage and disengage all other gears ok? Does it crunch when selecting reverse?
I rebuilt my box a couple of weeks ago and found i could not get it into 5th. When rebuilt the box i used a thread sealer on the selector rod detents. A small ammount of thread sealer had run into the detent and locked the plunger into the detent caseing therefore not allowing the plunger to push back to allow 5th gear to be selected.
goes in every gear fine just every now and again gets stuck in 5th
the clutch is new had the engine rebuilt it has dine about 2-3k at most
it does crunch sometimes in reverse but always put it in first before i go into reverse had vauxhals what have always done that
![Mad](https://passionford.com/forum/images/smilies/mad.gif)
155lee
14-09-2015 07:37 PM
CabrioTurbo
01-08-2015 11:04 AM
