omex launch control
Old Oct 17, 2007 | 09:35 PM
hutch's Avatar
hutch
Default omex launch control
has any 1 had joy with omex fitted to fiesta rst runnin 200 bhp do you launch in 1st or 2nd ? cant get to grips with mine its running the limiter at 4k
Old Oct 17, 2007 | 09:45 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
is it not adjustable?
Old Oct 17, 2007 | 09:51 PM
hutch's Avatar
hutch
Default yes
yes its ajustable ! just not really sure wat is the best way of going im very new 2 launch controll ! as my times at the pod this weekend reflected !
Old Oct 17, 2007 | 10:09 PM
RWD_cossie_wil
just play with it until you can launch the car off the line on wide open throttle, with little wheelspin and no bogging
Old Oct 17, 2007 | 10:26 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
On a fairly low power low grip RST i cant see how its gonna help much.
Its great for big turbos as it will get the turbo on boost before your going anywhere, but traction is always gonna be an issue as you on wide open throttle, and as you not got a huge laggy turbo it not helping you there either.
On normal road tyres i reckon youd be better off launching in 2nd if your using launch control, as im sure you can have it set to some revs where it wont bog down.
Old Oct 17, 2007 | 10:43 PM
daveb_lives's Avatar
daveb_lives
ive got it but havent successfully made it work,
204bhp fiesta rst and running 14.4 without it. will get it to work but in the spring i think
should bring the times down, i launch harder than 4k though im sure. should definately help get the power down though.
dave
Old Oct 18, 2007 | 12:11 AM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
5k launch
Old Oct 18, 2007 | 01:20 AM
Magic Numbers's Avatar
Magic Numbers
Originally Posted by adamski frst
5k launch
Girl = Adam
6.5k launches or above are the best! No point in fucking around like a homo
Old Oct 18, 2007 | 07:14 AM
polly_x's Avatar
polly_x
Its not really lauch control though is it. Just a temporary lower rev limit. You need to monitor wheel speed and adjust ignition/fuel for proper launch control.
The Omex thing is a gimmick really.
Old Oct 19, 2007 | 06:06 PM
daveb_lives
5k launch
indeed, area where torque is at its most and just a case of applyning that to the surface
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
dombanks
Sep 21, 2015 08:38 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
