2000 passat service light on dash
07-10-2007 | 04:11 PM
fookin thing gives a loud bong when ign put on and in big reg letters on the dash service now lol
how the hell do i switch it off doing my head in now, ps car has been serviced just not by main dealer
07-10-2007 | 04:12 PM
needs someone with the ability to turn it off to do it.
i can, but you're likely too far from me.
07-10-2007 | 08:37 PM
what do you mean by the ability?
07-10-2007 | 09:00 PM
Quote:
Did you get your scanner yet ?
If it`s got a VAG cartridge this will do it.......you will need the DL16 lead and S7 key.....the scanner will tell you the rest...
07-10-2007 | 09:15 PM
yer tried that m8 it said soming about ecu not listed on scantool database or similar
07-10-2007 | 09:17 PM
mmmmm What year is your PVCI up to ?
07-10-2007 | 09:22 PM
it does do everything else on the car mate for some reason just that one thing it wouldnt do
ive had it on all sorts of cars now including a 2005 astra all sems to work and pull/reset codes, bloody good tool once you get used to the menus
07-10-2007 | 09:24 PM
May need VAGCOM for that one then mate,will make some inquiries tomorrow.......maybe something stupidly simple though like holding the trip reset while you turn on the ignition or something...
07-10-2007 | 09:27 PM
i know im trying to look that one up too tried one method didnt work
08-10-2007 | 10:10 AM
You do need VAGCOM.
And when i say Ability, i mean VAGCOM lol.
08-10-2007 | 10:23 AM
VAGCOM
is that a new porn site
08-10-2007 | 11:23 AM
Quote:
Originally Posted by Sooty
VAGCOM
yes!
If random numbers and letters, with buttons that allow you to reset Service lights and air bag lights floats your boat, then VAGCOM is for you!
08-10-2007 | 11:25 AM
or just go and get it serviced ya tight arse
Luciano
08-10-2007 | 11:26 AM
Quote:
Originally Posted by SapphyMike
VAGCOM
yes!
08-10-2007 | 11:35 AM
on my 97 passat I can turn the service interval thing off just by using the buttons on the dash
08-10-2007 | 11:53 AM
*** Sierra RS Custard ***
Push and hold the milage reset while you turn on the ignition works on most of them around that age IIRC
08-10-2007 | 05:32 PM
na dont work on mine
if i was dodgy id just plug in my my mileage correction tool and wind the miles back a couple thousand that would switch it off
10-10-2007 | 08:49 PM
do a search this has been asked before!
10-10-2007 | 09:40 PM
Quote:
RIGHT MATE PRESS AND HOLD DOWN THE MILAGE BUTTON.AT THE SAME TIME PRESS THE FOOT BRAKE THEN TUR ON IGNITION.TILL TIMER COUNTS DOWN
10-10-2007 | 09:43 PM
IF THAT DONT WORK PM ME YOUR PHONE NUMBER AND I WILL PHONE YOU 2 MORO .IVE GOT AUTO DATA ON MY COMP AT THE UNIT AND WILL CALL YOU 2MORO WITH DETAILS
11-10-2007 | 08:30 AM
no m8 i pressed the button pressed the brake then turned on ignition and nothing
madness as most cars are easily done
11-10-2007 | 08:32 AM
Instructions are in the car handbook
11-10-2007 | 04:21 PM
11-10-2007 | 08:50 PM
sorted it
you have to press the right button turn on ign wait a few secs then turn the left button clockwise and hold
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
fuzzy
04-09-2015 10:11 PM
hopper350
04-09-2015 12:53 AM
CrOwSoN15
14
03-09-2015 12:21 PM
turbowag
03-09-2015 08:07 AM
