different EVO models...????
Old Sep 27, 2007 | 06:16 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default different EVO models...????
before u say it,my account wont work on the MLR site.........
can someone please explain what all the different models are/mean....eg GSR....MR....FQ....etc and what types to go for... i'm looking at evo 7's and 8's ...cheers Pete
Old Sep 27, 2007 | 07:29 PM
ECOS95's Avatar
ECOS95
FQ's are UK supplied cars normally FQ300, FQ330 the MR's are the improved FQ's and normally FQ300, FQ320, FQ340. GSR are normally imports from Japan I think. FQ260 are only on the Evo VIII. MR's cost more normally but are the most tuenable due to the uprated parts fitted at the factory.
Old Sep 27, 2007 | 09:29 PM
pete mcrash
hey!!!.....thanks for helping..........
Old Sep 27, 2007 | 09:49 PM
Dicko&Vacant's Avatar
Dicko&Vacant
here we go again
Old Sep 27, 2007 | 10:00 PM
pete mcrash
Originally Posted by Dicko&Sarah
here we go again
....do u know anything about different evo models..???????....er NO....so fuck off.....................
Old Sep 27, 2007 | 10:04 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
RS's are the 'track' spec - they have very little in the way of luxury stuff and they don't have the Active Yaw Control etc. Very much a drivers car. Shorter gear ratios too as i remember...
GSR's are the 'comfort' spec - they have all the luxury bits and the AYC etc. Still a nice drive, but heavier and taller geared.
FQ's are 'spruced up' with very average and exceedingly expensive parts.
MR's are the daddies I would advise anyone to get an MR as the bottom end will do 400lb/ft and a bit as opposed to throwing a rod at 350lb/ft, the turbo is bigger and the cams have an extra 1mm of lift...
Hope that helps...
Old Sep 27, 2007 | 10:06 PM
rs_daz's Avatar
rs_daz
You can look at all the models on the MLR
http://www.lancerregister.com/mlr_showmodel.php
Im hopefully going to a Evo 5 soon
Old Sep 27, 2007 | 10:13 PM
Dicko&Vacant
here we go again
i know yours will still say cosworth on the back cause you will only bottle it again
Old Sep 27, 2007 | 10:26 PM
rstoughy's Avatar
rstoughy
I got an RS2 FQ300 VII.
Best of both worlds really.
The RSII means it has a mixture of RS bits and GSR bits, like it has Electric windows but doesnt have the folding mirrors, Has nice Recaro seats not the throw away RS ones, no rear wiper, no rear head rests, no carpet lining in the boot over the back seat, no adj wiper speed ect ect
and of course it has 300hp out of the box.
If i was to buy another it would deffo be an RS or an MR as my future plans for mine are Autronic, MR Cams and an MR turbo.
Good luck with your choice as i was amazed with the amount of different models there is out there
Old Sep 27, 2007 | 10:35 PM
ESCYSCOTT's Avatar
ESCYSCOTT
Pete, if I was you i'd go for an RS version as the AYC won't cope with the hammering you give to cars and you'll be forever fixing the thing................sounds spookilly like cosworth ownership.
I'd go with your original plan of a Subaru WR1
Old Sep 28, 2007 | 05:33 AM
Redkop's Avatar
Redkop
Default Re: different EVO models...????
Is this anything to do with our phone conversation the other day?
The RS models only have 5 gears, as does the Evo VIII 260 and Evo VII
The VIII FQ, MR and GSR models all have 6 gears.
You should be able to see MODEL COMPARISONS without having to login to MLR.
Old Sep 28, 2007 | 05:34 AM
pete mcrash
here we go again
Old Sep 28, 2007 | 05:38 AM
pete mcrash
thanks for the links people but they dont answer my questions......... .....and Scott.............the new super AYC (8's) has been designed a lot better and is ment to be well up to the job.....
Old Sep 28, 2007 | 05:44 AM
Redkop's Avatar
Redkop
I thought ECOS95 answered your questions....
What else do you want to know?
Old Sep 28, 2007 | 05:52 AM
pete mcrash
...yes he was the best..... ....but the links to the MLR dont go throught the different models,just different evolutions ie 7's 8's 9's.....
Old Sep 28, 2007 | 06:00 AM
Redkop's Avatar
Redkop
You asked what the different models mean... I think the replies made have covered this question, so I'm not sure what it is you actually mean
Does this help?
Model Codes
Each Evolution model had a different 4-digit start of the chassis number [the V and VI were the same, CP9A, VII, VII GT-A and VIII were also identical, they used CT9A - see Technical Specification for the full list].
There is also a model number to distinguish between the GSR and RS. The tables below show the meaning of each digit [example is an Evo VI TME GSR]:
What's the difference between the GSR and RS?
The Evo I to III RS and GSR employ the same gearbox. The later Evo's are however, different. The GSR box has longer gearing.
The RS Model hasn't got ABS or AYC and the car is between 70kg and 100kg lighter [dependant on model - see Technical Specification] due to lighter panels and lightweight window glass. Although weight could be reduced further on the RS model by opting for the thinner gauge body, or by asking for a car minus the aerodynamic appendages.
There are a few more technical differences. These are:
Option of twin-plate clutch [from the 1996 Evolution IV]
TD05HRA-16G6-10.5T titanium turbocharger was employed on the Evolution VI onwards
RS has closer gearing for better acceleration. But top speed is between 125mph and 150mph depending on model.
RS's 0-60 is a fraction faster than the GSR times
The RS also has a quicker steering rack, 2.1 max turns [2.3 on the GSR]
Option of either a normal open front diff or a helical gear Limited Slip Diff ['worm gear' type]
Rear differential is a mechanical LSD
There are a few cosmetic differences also. These are:
The RS has black door handles and wing mirrors
The RS has no rear wash wiper
The RS has no front fog lamps**
In some cases the wheels are 15" steels [it was option to have GSR wheels]
The RS has no Climate Control, electric windows or mirrors; the seats are slightly different
The RS is available in Scotia White only
Smaller leather Momo steering wheel [365mm] with no airbag
No central locking and no radio-type keyless entry system
** For the GSR models that have foglights, the RS bumper is the same but has the spaces blanked out with covers
As for refinement, the GSR is the more refined of the two. It has all the extras you would find in any saloon car such as climate control, electric windows, electric mirrors, Alloy wheels etc.
The RS seats are more like the traditional bucket seats used in competition cars. Rally teams don't want climate control, nice seats, alloy wheels, ABS etc. as they would just have to ditch it all and replace it for high specification rally items or lose most of the equipment completely to save weight. The RS is a popular car with Group N teams.
The RS is a cheaper car, so if you were thinking of using the Evo a few times a month for a blast and for track days then the RS would seem a better option. But, if you are planning on driving the car frequently and like your luxuries then don't even consider the RS.
Other Evolution Models
OK, so you are clued about on the GSR, RS, but there are other Evo's you need to be aware of. From the 1992 Evo to 1996 Evo IV there were just the standard two models; The GSR and RS. The differences between these models are covered above.
There are some other models for the Evo V, VI, VII, VIII, VIII MR and IX. After the arrival of the Evolution V in 1998, the Evo model became a cult icon in the UK. Ralliart began to import the Evolution V and the Evolution VI. With years of knowledge and experience behind them, Ralliart began to experiment with the Evolution.
Below is some basic information on these extra special Evo's.
Evolution V/VI RS450 - UK Model
The RS450 upgrade was only fitted to the Evo VI. Although one Evo V RS did have the conversion done [white one featured in some magazines]. There were only 4 or 5 all based on eXtremes, and were based on the RSII, not an RS. So, air con, long gearing but no AYC or ABS. AP brakes were fitted to most of them but it wasn't mandatory and some had 4pot fronts with Brembo rears while the better option was 6pot front/4pot rear.
Why was it named the RS450? That was the torque figure they aimed for but never achieved. One has been measured [rolling roaded] at 383lbs/ft with 379bhp. 0-100 appears in just 8.8 seconds. A psychotic car! Ralliart also reckon 0-60 will appear in under 4 seconds. The original price tag was Ł44,000! Rare as rocking horse s**t! I have never seen one in the flesh. All the customer cars were mapped conservatively to make sure that none exploded - which they didn't! More aggressive mapping would get much nearer to the aimed 450lbs/ft.
Evolution VI/VII RSII - European Models
The RSII is a cross between a GSR and RS. From the Evo VI onwards there is also an RSII version that sits in the middle ground between the RS and GSR but is basically an RS with some added GSR equipment. The RS and RSII is also available in LHD, the GSR is available in RHD only.
Evolution VI/VII RS Sprint - UK Models
The Evo VI RS Sprint is a Ralliart tuned Evo VI RS that produces a healthy 320bhp. Modifications include a Ralliart ECU, ARP conrod bolts, HKS exhaust system and HKS air filter.
Evolution VI RSX - UK Model
It doesn't have AYC or ABS or climate control but it does have electric windows and mirrors and has aircon. It has upgraded Recaro SR seats with more thigh support than the standard GSR. It has the standard GSR gearbox but also has the Torsen front diff.
It also has a big 16G titanium turbo. This is the same turbo as the GSR but with a titanium shaft and turbo wheel and it isn't the same as the small titanium unit used on the Makinen editions. Some of the RSX's have had ARP conrod bolts put in but even Ralliart can't tell you which ones have and which ones haven't!!!
It also has a modified ECU to take account of the fact that there is no ABS and AYC. As a result of all this it weighs 1280kgs, which is approximately 80kgs less than the GSR. Due to the lighter weight it is supposedly slightly quicker to 60 but you're only talking tenths of seconds.
Evolution VI Tommi Makinen RS Monte Carlo - UK Model
The "Monte" is a Ralliart tuned Evo VI Tommi Makinen RS that produces a healthy 320bhp. Modifications include a Ralliart ECU, ARP conrod bolts, HKS exhaust system and HKS air filter. The front seats are changed to a pair of Recaro Black Recliners and the normal TME badging is changed to "Monte Carlo". Only 12 of these models were produced and to date, remain one of the rarest Evo's.
Evolution VI/VII/VIII Extreme/Extreme S/Extreme SC/Zero Fighter - UK Models*
Now, these are the ultimate Evo's. A few cosmetic changes, white and red colour-coding. The real deal! Not for the faint-hearted.
Head of tuning at Ralliart UK [now Xtreme Autos - See Ralliart goes "Xtreme"] Toney Cox stated that you would need a serious motorbike to keep with the Extreme [Quoted from the Mitsubishi Lancer Story DVD] I can believe him! The Evo VI Extreme can be picked up for under Ł25k now. A bargain! Power figures are as follows:
VI Extreme/Zero Fighter : 340bhp : 303lb/ft of torque
VII Extreme : 339bhp : 350lb/ft of torque
VII Extreme S : 357bhp : 383lb/ft of torque
VII Extreme SC : 458bhp [500 is available] : 410lb/ft of torque
VIII Extreme : 337bhp : 320lb/ft of torque
*Zero Fighter was tuned by MMC Japan.
Evolution VII/VIII FQ-300/FQ-330 - UK Models
These are basically slightly tuned GSR models. Some question the price of the FQ models as an upgrade to a GSR model would be cheaper than buying an FQ model.
VII FQ-300 : Exhaust system/filter : 301bhp : 300lb/ft of torque
VIII FQ-300 : Exhaust system/filter : 301bhp : 300lb/ft of torque
VIII FQ-330 : Exhaust system/filter/ECU : 330bhp : 305lb/ft of torque
Evolution VIII MR FQ300/320/340 - UK Models
VIII MR FQ-300 : Base Model: 301bhp : 289lb/ft of torque
VIII MR FQ-320 : Exhaust system/filter : 320bhp : 300lb/ft of torque
VIII MR FQ-340 : Exhaust system/filter/ECU : 340bhp : 320lb/ft of torque
Evolution IX FQ300/320/340/360 - UK Models
IX FQ-300 : Base Model: 301bhp : 289lb/ft of torque
IX FQ-320 : Exhaust system/filter : 320bhp : 300lb/ft of torque
IX FQ-340 : Exhaust system/filter/ECU : 340bhp : 320lb/ft of torque
IX FQ-360 : Exhaust system/filter/ECU : 366bhp : 363lb/ft of torque
Old Sep 28, 2007 | 06:06 AM
Bullett's Avatar
Bullett
i dont know which are best but imo if i was having a choice between the 7 and 8 its has to be the 8 all day,the looks of a 7 just arent hard enough for an evo.
have to say though the 6 i borrowed was an waesome motor so,so capable.
Old Sep 28, 2007 | 10:51 AM
Staffi's Avatar
Staffi
Fair play to that Lynne..
He'll still complain..
Old Sep 28, 2007 | 11:48 AM
Redkop's Avatar
Redkop
Well if that lot doesn't answer any of his questions..... I don't know what the fook will
Old Sep 28, 2007 | 04:28 PM
ECOS95's Avatar
ECOS95
Out of the 7 or 8 I'd go for an 8 300MR and tune it. The savings from the 320/340 should cover the cost of the tuning & you'll have a better car at the end of it.
Old Sep 28, 2007 | 05:38 PM
Redkop's Avatar
Redkop
Most people on MLR advocate the VIII FQ MR320 as the best one to buy if you want to mod.
Old Sep 28, 2007 | 06:15 PM
pete mcrash
....no i'm happy...ish.....
Old Sep 28, 2007 | 06:18 PM
Staffi's Avatar
Staffi
So what's your plans Pete, i take it the saff is going for an Evo then??
Old Sep 28, 2007 | 06:21 PM
Redkop's Avatar
Redkop
Did I put these thoughts into your mind Pete?
Old Sep 28, 2007 | 06:22 PM
pete mcrash
.at the moment its a money thing......waiting for a good payrise so instead of spending it on gearbox,diffs,head work etc.....i'd rather get something newer(and hopefully more reliable) as an everyday car......
Old Sep 28, 2007 | 06:23 PM
pete mcrash
.....no my dear.....its been coming........
Old Sep 28, 2007 | 06:26 PM
Staffi's Avatar
Staffi
Well you're making a good choice of car anyway..
Think i might get myself another one next year..
Old Sep 28, 2007 | 06:32 PM
Redkop's Avatar
Redkop
To whet your appetite Pete...
Old Sep 28, 2007 | 06:36 PM
marco polo's Avatar
marco polo
here we go again
pete mcrash
i (might ) have sorted my tuner/mapper aswell...........i just need pectal......
Old Sep 28, 2007 | 06:57 PM
morto's Avatar
morto
rs models if you want a track car or gsr for all mod cons mine is a 95 spec and has loads of stuff
andy
Old Sep 28, 2007 | 07:03 PM
pete mcrash
andy
....cheers fella but its a evo 8 (or a very good 7) that i'm after........
Old Sep 28, 2007 | 09:13 PM
Staffi's Avatar
Staffi
This 9 RS does it for me Lynne..
defo a 9 for me next time..
Old Sep 29, 2007 | 05:51 AM
Redkop's Avatar
Redkop
I shan't be replacing my VIII - no need to, it's just how I want it to be
Will be getting a hard pipe kit fitted shortly
Old Sep 29, 2007 | 09:42 AM
ECOS95's Avatar
ECOS95
Have to admit I haven't seen many MR300 around when I was looking at the different models. I'm more tempted by a IX but the VIII does come a close second.
Old Sep 29, 2007 | 10:38 AM
This web site will soon b called "passion dont own a ford"Lol
Old Sep 29, 2007 | 10:48 AM
Redkop's Avatar
Redkop
I still own a Ford... albeit a Fiesta 1.4 TDCi
Old Sep 29, 2007 | 11:11 AM
Staffi's Avatar
Staffi
Alot of the people who own Evos/Subaru etc went from Fords and some still have Fords in the Family....Don't they Lynne..
Think you'll find aswell, the people who own these make of cars STILL like Fords, BUT people want to try elswhere and there's nothing wrong in that..
Old Sep 29, 2007 | 11:48 AM
ESCYSCOTT's Avatar
ESCYSCOTT
tends to be that a lot of people return to a Ford too after owning an Evo or Subaru.
I would like an Evo 5 or 6 Extreme or something like that but don't think i'd like the hit on the depreciation of it really and I definately wouldn't sell my Escos for one even if they do drive a million times better than the cossy. It's the heritage thing that I love about an Escort Cosworth that is part of the pride of owning such a car.
Old Sep 29, 2007 | 01:55 PM
Redkop's Avatar
Redkop
MLR is full of ex cossie owners who haven't returned to a Ford. I know I'll never return to cossie ownership..... pride and heritage sadly don't make up for newer technology and reliability.
