HELP- Cosworth ISCV wire colour ???? NOW SORTED
Old 03-10-2004, 12:51 PM
Default HELP- Cosworth ISCV wire colour ???? NOW SORTED
Just took the connector off to fit another one, went inside, came back out and forgot which wire goes which side
Looking down on the ISCV from the front of the car as fitted into the car, does the red/black wire go on the left or the right side of the ISCV
help much appreciated
cheers
PAUL
Old 03-10-2004, 01:14 PM
Dilly
Dilly's Avatar
don't have a red/black wire on mine but i know the one on the left if looking from the front of the car is the live
Old 03-10-2004, 01:42 PM
thanks, sounds about right as I assumed the red/black was switched live and thought it was on the left side of the connector.
Can anyone confirm
thanks
Old 03-10-2004, 03:05 PM
can anyone put my mind at rest before I connect it up.
All you need to do is pull up the rubber from the connector and confirm what colour wire is on the left hand side
please please please
Old 03-10-2004, 03:33 PM
frog
0-60 in 17 seconds (eek)
frog's Avatar
Brown+Yellow - engine side.
Black+Red - coil/battery side.
on a 2wd cossie.
Old 03-10-2004, 03:49 PM
really appreciate your help Frog, you saved me nearly putting them the other way around
thanks mate
Old 03-10-2004, 03:55 PM
frog
frog's Avatar
now I hope I got it right
Old 03-10-2004, 03:58 PM
ImaRacing 700
ImaRacing 700's Avatar
I do believe it doesnt matter which way round it goes!
Could be wrong though...LOL.
Old 03-10-2004, 03:59 PM
GARETH T
GARETH T's Avatar
Rock Your World, yes you could be
Old 03-10-2004, 04:05 PM
ImaRacing 700
You sure gareth?...as it dont matter on the amal valve or the injectors...
Old 03-10-2004, 04:12 PM
Well I just connected it all back up as per frogs description and she is running sweetly again from cold - the original connector felt loose and I thought that may the problem, and it appears to have been the case
Old 03-10-2004, 04:22 PM
frog
frog's Avatar
Old 03-10-2004, 05:17 PM
ECU Monitor Enthusiast
POLARITY DOES MATTER.
On 4x4 and retro fitted idle valves, they have a voltage protection diode
within the valve and if you wire it backwards it will NOT work.
(If wrong, it will effectivly short out and eventually damage the ECU)
Some valves do have a + mark on them but not all.
If it does not work, try reversing the polarity but only make a short duration
test time to prevent ECU damage !
Old 03-10-2004, 05:20 PM
GARETH T
GARETH T's Avatar
SECS, i thought i remember seeing a flywheel diode in some diagram i read long time ago,, but i wasnt 100%
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
Roosie
15-08-2015 08:09 PM
14-08-2015 07:29 AM
fatboy billy
03-08-2015 08:34 AM
Quick Reply: HELP- Cosworth ISCV wire colour ???? NOW SORTED
