please help turbo boffins
This is'nt a techie question more of a opinions please.
Brought a 500bhp 3 door off a guy built by a reputable builder wont name names but it was fine for about a day or so.
Then it started to smoke so traced the fault to the turbo GT30. So i rang the engine builder who offered to repair the turbo which he did'nt have to do as we did'nt have the engine built there the previous owner did.
So the turbo came back after a few weeks we bolted it back on and it smoked again . I rang the builder back and he said send it back again i will get it sorted.
While the car was off the road we bolted on a T34 and went to national day and it did'nt smoke at all so it was deffo the turbo.
Anyway its come back again and its still smoking
So i have been told that you need a restricter on the top of the turbo which it has and it also has a turbo filter so it can't pick up any debris.
any other ideas as i know some of you use these turbos has anybody done anything different than me??
Originally Posted by 68332
If it smokes, the turbo is fooked or its plumbed as a suck through layout
and the seals are leaking due to high vacuum.
I.E. The throttle is BEFORE the turbo inlet
frstben,
The turbo is fooked unless the oil drain is blocked ????????
Its had 2 different rear seals by the sounds of it...
If the rear seal was letting go, and its been back to be sorted twice, then it will have had replacement rear seals both times
How bad is it smoking????
Originally Posted by frstben
yes but i like how the gt30 pulls but i am loosing faith in them whats the difference between having it redone and buying a new turbo??
if you see my point....
Well for a start i would stop posting half hearted remarks and ring them to explain what the issue is...
I've done the leg work for you here's the number...
Telephone +44 1425 638426
P.S Did you buy the white 3door which A1 rebuilt!?
This one?
This one?
This one?
This one?
I have rang various other turbo places which say that this is the only one that is giving these simptoms so could it be something else maybe .
I get something similar on mine, smokes in the morning if its left to sit, if you drive it theres nothing at all. Had the turbo rebuilt, but still there, very odd....
So you've spoken to CR Turbo's directly have you? Or just the tuner who built the engine.....I'm sure they would know who you were if they'd had a GT30 back twice for the same fault.
Might be something simple like a seal not completely working properly (If ya see my point)
By getting everyones information together in one pot this makes the solution a lot easier to come by!
the engine builder didnt do the turbo it went to cr turbos
smit...learn to read
if vince has touched it, and your still having probs, then i cant see it being the turbo tbh....
maybe a dodgy union
but im happy to have a look for a small charge
maybe a dodgy union
I was enquring about why he hasn't phoned Vince to ask opinions...
JK12
33
26-04-2021 01:09 PM
