can i buy diffrent jets for my amal valve?
saff is working!!!...atm
do u not think of asking ur tuner questions before u buy shit..?????..i know u live in OZ but a little research would've saved u lots of saw fingures on here.........u need to talk to Stu, maybe he can tell u (an average) size jet to use........
Re: can i buy diffrent jets for my amal valve?
as above please
as above please
Passion for Fords!
i removed the return to air filter restrictor, so the amal valve can bleed off more air, as it will need to do with an increase in boost pressure, if you dont do this ,the wastegate actuator will still see enough pressure to open, and you will imo struggle to get over 23-24 psi
but left the other one alone.
i now peak at 32 and hold 28
so u took the air filter one out?
can you explain to me how boost is set and held?
cheers mate
