BMW Techies again - E39 Aircon - anyone knowlegable?
Team HOTHOT!
Quick question that I've asked on the E39 forum, but people on there are too slow to even reply
Here is what I asked:
"Am I right in thinking that if the Air Con system pressure is low, or the refrigerant has escaped somehow, then when you press the button for the Air Con to start on the control panel, it will not engauge the compressor via the magnetic clutch or the auxillary fan infront of the radiator? (In order to prevent any damage to the compressor as from what I know about air conditioning (very little. lol) the refrigerant is also a lubricant for the compressor internals?)"
Any of you lot (AlexF in particular) got any idea?
Testing the future
it will not engage the compressor, but the fan may still come on at low speed. depends how they are controlled, probably both via the engine management on that, so probably neither will start
the only way that the system pressure will be low is if the refrigerant has escaped, or it is very cold outside
alternatively, the pressure switch / transducer may have failed
Team HOTHOT!
Righty
Done a check, and the system pressure is low, infact, its nearly empty with only air coming out of the fill valve and no refrigerant
So that explains one thing
Next question is where is the best place to get the aircon re-gassed, oiled and refrigerated?
Looking at the service history, it has never been done on my car and with it being only 5 years old, I can't see there being a problem with leaks unless something major has gone wrong (again, looking at the S/H there is nothing to suggest any aircon probs)
My mondeo A/C leaked out its refrigerant, so although the light came on, nothing happened. I had it re-charged, and it worked fine for about a day, then one of the hoses split, was oily goo everywhere! Could be a sign that one of your hoses is on its way out perhaps? Make sure you get a proper pressure check carried out when you have the a/c service done
Got the hose replaced, and its all fine now
Testing the future
there will be a leak somewhere - all of the refrigerant should not have leaked out in 5 years.
first thing that a service place should do is a vacuum test - that will show any major leaks, but will tell you nothing about where they are (if they show up under vacuum, as many do not)
next they should pressurise with dry nitrogen and leak check. best way to find a leak is a washing up liquid solution sprayed all over (i would suspect a stone hole in the condenser first of all). no leak dye or all that bollocks
once leak has been identified and rectified, then vaccum and recharge adding any oil if necessary
Originally Posted by Graceland
Wheres best to get aircon serviced then? and do not say bmw
He will charge you about £20 just to check the system, but he wont do any repairs.
jonfoc
16
11-09-2018 05:35 PM
