BMW tech heads...
Old Aug 31, 2007 | 10:51 PM
biglee's Avatar
biglee
Audio specialist
Default BMW tech heads...
hi chaps.... apparently there is a particular oil and type i need to use for my M3... any ideas??? coz i dont bloody know what it is..
Old Aug 31, 2007 | 10:55 PM
dave cos4x4's Avatar
dave cos4x4
iirc think it may be 0-30 fully syn.
get more advise though.
Old Aug 31, 2007 | 10:57 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
No Dave, there is a VERY specific oil recomended, I dont recall the reference for it though.
JJ will know
Old Aug 31, 2007 | 11:01 PM
Mike1's Avatar
Mike1
They used to recommend Castrol TWS 10-60 ( also known as Formula RS ) - now known as Edge 10-60 - for the M3 and M5
Not a "proper" synthetic though
dave cos4x4
Chip-3Door
i do recall seeing the 0-30 oil in Castrol,they said it was for BMW performance cars,cannot think what its called though.
Old Aug 31, 2007 | 11:04 PM
dave cos4x4
have a read on here.
http://forums.bimmerforums.com/forum...d.php?t=567548
Old Aug 31, 2007 | 11:14 PM
Chip's Avatar
Chip
Chip-3Door
Its the TWS mentioned above that I was thinking of.
I believe its specifically recomended for the M3 and M5's of that era, but not for other BMW's
Old Sep 3, 2007 | 10:03 PM
biglee's Avatar
biglee
Audio specialist
ok so i still dont know
Old Sep 3, 2007 | 10:06 PM
messcortmk6's Avatar
messcortmk6
does it really matter? cant you just be simple and just use castrol magantex? i dont think it really maters, bet BMW just has a deal with the specific company so they get a bit of cash from it too.
Old Sep 3, 2007 | 10:08 PM
biglee's Avatar
biglee
Audio specialist
no no no its all to do with looking after the vanos system.. if you use the wrong oil it seriously affects the life of it...
Old Sep 3, 2007 | 10:16 PM
JjCoDeX75's Avatar
JjCoDeX75
As mentioned by Chip, the correct oil is the TWS. It was designed by Castrol in conjunction with the M3 and M5 engines.
BMW themselves for a while said that the later M5 could be used with the newer oils that they used in the other cars, but then realised that actually, the TWS was still the superior oil for the car.
Pissing expensive if bought from BMW (about 15 quid a litre!!!!), and this is the only over the counter place to buy it from.
I buy mine direct from Castrol Classic Oils. They are found online, and are easy to deal with. The other alternative is Opie oils.
Although many say that Castrol Edge 10W60 is the same (which it might well be!), I still use the original TWS that was specced for the engine. You cant go wrong then, can you!
As an aside, the TWS was imaginatively named (Ten Weight Sixty)
JJ
Old Sep 3, 2007 | 10:27 PM
biglee's Avatar
biglee
Audio specialist
Spot on matey... thanks for the help...
i think millers do a 10-60 semi which is expensive but should do the trick.. looking at the spec itgs very similar...
cheers..
Old Sep 3, 2007 | 10:35 PM
messcortmk6
oh right cool, interesting, i would have never thought it, lucky i will never own one then, i personally dont like bmw, dont ask why i just dont.
Old Sep 3, 2007 | 10:47 PM
Steven_RW's Avatar
Steven_RW
nah stuff that - who cares what oil bmw M division spec for it. I'm gonna use MAGNATEC cos its cheaper!
lol
RW
Old Sep 3, 2007 | 10:54 PM
blacky.'s Avatar
blacky.
its 0-30 castrol edge
it is expensive like
i used the 5-30 fully synthetic we had in the pumps at work in my B10 as it was free ssssssshhhhhhhhh
Old Sep 4, 2007 | 04:37 PM
JjCoDeX75's Avatar
JjCoDeX75
cheers..
Hi matey
Millers is usually pretty good oil, so it should be okay I guess. Make sure the specs are the same though
I have only ever used Castrol, so cannot comment otherwise.
The E39 M5 drinks oil at the best of time. Rumour has it that if you use the wrong oil with that car the oil consumption goes through the roof (which I can believe). I dont think the M3 has the same curse!
JJ
Old Sep 4, 2007 | 04:47 PM
AlexF's Avatar
AlexF
Default Re: BMW tech heads...
what M3?
Which eninge?
What year?
then I'll tell you EXACTLY whats recomend (tomorrow) lol
alex
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
