Can a "weld on" wing be fitted with nuts + bolts??
Old 21-08-2007 | 06:59 AM
cossie04's Avatar
cossie04
Default Can a "weld on" wing be fitted with nuts + bolts??
As title really, i have 2 brand new wings for my sierra but i don`t have a welder and was wondering if i could adapt it to nuts and bolts to make them bolt on wings???
Its only my XR4i so not worried about origanality really....
Cheers, Ed.
Old 21-08-2007 | 07:23 AM
Bomber's Avatar
Bomber
I was always under the impression that the MOT requires replacement panels to be attached as they were originally when the car was assembled.
Old 21-08-2007 | 07:55 AM
cossie04's Avatar
cossie04
Hmmm, i knew there had to be something stoppin me . Cars really piss me off...
Cheers m8
Old 21-08-2007 | 08:45 AM
jacko's Avatar
jacko
as long as its secured and you make it look right then there is no problem
Old 21-08-2007 | 10:01 AM
THEY HAVE TO BE WELDED, or rather according to the MOT bilble fixed in the SAME MANNER as the oe manufacturers fitting.
Old 21-08-2007 | 11:27 AM
matts1's Avatar
matts1
if both wings are replaced and fixed using bolts done in a way that looks factory, then I am sure most garages will not even notice.
A few eagle eyed places may stratch their head thinking "I am sure they are normally welded on" but if it looks good enough, i reckon you would get away with it.
Old 21-08-2007 | 11:31 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I dont see how you could nut and bolt it anyway, fair enough along the top, but not at the bottom :S
As above though, would be an MOT fail and an insurers way out of paying a claim potentially too.
Old 21-08-2007 | 11:38 AM
Twellsie's Avatar
Twellsie
so how do you go about attaching fibre glass wings?
jon@work's Avatar
jon@work
so how about carbon fibre/fibreglass wings then ?
oops beaten to it
Old 21-08-2007 | 11:42 AM
cossie04's Avatar
cossie04
Just rung my local MOT station, he said its fine but he would prefer the wings to be bonded aswell as bolted on, but apart from that, no worries.
Selling it now tho, lack of space and money...
Cheers for the help people...
Old 21-08-2007 | 11:59 AM
Retro Al's Avatar
Retro Al
RWD IS KING
mine have been converted to bolt on/off had no probs with the mot
Old 21-08-2007 | 04:43 PM
jacko's Avatar
jacko
drill holes put spire clips on then use self tapping bolts same as the vauxalls
Old 21-08-2007 | 06:36 PM
dojj's Avatar
dojj
Resident Wrestling Legend
bolt on won't give the same strength in an impact as welded wings though, same with the fibreglass ones
so whats the dealio with them then in case of an off into the armco/traffic light/pedestarian?
Old 21-08-2007 | 06:39 PM
jacko's Avatar
jacko
if its just spot welds then the bolts if done right should be as strong if not stronger
Old 21-08-2007 | 07:21 PM
It is VERY CLEARLY STATED in the MOT book for anyone that reads it.
Old 21-08-2007 | 07:30 PM
jaimesdna's Avatar
jaimesdna
it states a lot of thigs in the mot book but lets face it, that dont really mean much if you go to the right place
Old 21-08-2007 | 07:39 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Not that I have seen
Old 22-08-2007 | 09:14 AM
Markb_s1's Avatar
Markb_s1
mine are converted to bolt on too...
re strength.. i don't believe the outer wings effect strength a great deal anyway.. it's all in the chassis rails/inner wings.
JoeyBoyden
04-01-2024 02:36 PM
3i Jim
20-11-2015 05:12 AM
M K
12-08-2015 06:57 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: Can a "weld on" wing be fitted with nuts + bolts??
