unlocking for displays
Frog Tosser
Unlock the Digital Dash on Fords
This information sold on eBay as
UNLOCK YOUR FORD LCD DASH DISPLAY FOCUS PUMA FEISTA
Ford Puma Digital Dash Unlock - MPH / KPH / Revs etc.
Unlock Digital Dash on Ford FOCUS FIESTA MONDEO ESCORT
Unlock Your Ford Cougar / Mondeo / Focus / Ka Display
Details
Self Diagnostics Mode
The Self Diagnostics Mode gives you in-depth information about your
engine and the actual numbers in digital. To use it, follow the steps:
* Insert Key but do not turn it on
* Press and hold the Trip Meter Reset Button
* While holding the reset button, start your car and continue
holding the button
* Within 10 seconds, the display should change to "test" in LCD font
and the needles will do a full sweeping. Release the Button
Pressing the button will now cycle through some 17 different modes
* 1.Shows a Gauge Sweep
* 2. Shows all 8's on the LCD (LCD TEST)
* 3. Illuminates all the bulbs on the dash
* 4. Displays hexadecimal value for ROM level
* 5. Displays the hexadecimal value for EE level
* 6. Shows DTC (Diagnostic Trouble Code)
* 7. Digital Speedometer - mph
* 8. Digital Speedometer - kph
* 9. N/A
* 10. Digital tachometer
* 11.Fuel volume
* 12. Engine coolant temperature
* 13. Battery voltage
* 14. ABS fail
* 15. Electronic brake distribution (EBD) failure
* 16. Illumination
* 17. Crank Sense
Details
holding the button
* 9. N/A
* 11.Fuel volume
* 14. ABS fail
* 16. Illumination
* 17. Crank Sense
